For those of you with cruiser coils
Old May 18, 2005 | 12:04 AM
Blizzard's Avatar
Originally Posted by PAhydrohead
Thanks David,
You should see it now with an ARB winch bumper, and 33" BFG MTs on ALCOA rims (See page 2 here https://www.yotatech.com/forums/show...9&page=2&pp=25)
Yea, that bumper is well, ahh, temporary.....Mike, hint, hint.
I can't mic the coils until Thursday. I'll let you know.
Hehehe, I linked your pics in my forum a week or two ago. I want you 4Runner but with my engine hahaha.
I liked that your tires don't stick out too much, here is mandatory to have the wheels covered with fender flares, and I've my 31's in the very edge of my fender flares hehe
http://img218.echo.cx/img218/4969/dsc019923oq.jpg
Sorry for the hijach, I want to do this setup next year or so...
David
Old May 18, 2005 | 06:40 AM
RobG's Avatar
Originally Posted by Robinhood150
When I sit on the tailgate (I weigh 150) of mine, the truck sags 1 inch as measured at the tailgate.
Steve,
I get very similar movement when adding weight to my tailgate. I took the measurements a while ago when I was considering a new rear bumper, I decicided against it for just that reason.
I got very close to 4" from the coils with the back empty, add a larger spare and tools and it is about 3+ inches now, load it up with camping gear and I try not to look at it. I am running a 4" bracket lift up front.
I am going to add a spacer and/or switch to OME 862's which are a little stiffer and 1/2" longer. Slee talked me out of 862's initially because I didn't have a lot of weight in the rear.
Picture attached, coil diameter measures .60" and .61".
Old May 18, 2005 | 05:39 PM
KevyWevy's Avatar
ok so i got some measurements. (I was bored today)
'93 FJ80 Coils under no load:
1' 7 1/8" tall = Long Side
1/6 9/16" tall = Short Side
Diamiter of both sides is 3cm exactly
'94 4Runner Coils under no load:
1' 2" = "Short Side"
1' 2 1/16" = "Long Side"
Diamiter of both sides is 13mm exactly
'96 FJ80 Coils on my 4Runner and BJ spacers in the front. measurements are rim to fender with a 15" rim with a full tank of gas and nobody sitting inside. with 2 10" MTX subs and a tool box in the back.
Passenger Rear = 1' 3 7/16"
Passenger Front = 1' 3 1/2"
Driver Rear = 1' 3 3/8"
Driver Front = 1' 3 1/4"
Difference in height on the tail gate from the ground with me sitting on it and me not sitting on it is 1 15/16" and i weigh about 200 lbs.
hope those help, let me know if you need any pics of FJ coils compaired to 4Runenr coils.
Old May 18, 2005 | 05:44 PM
Cebby's Avatar
3cm = 30mm, right? That means tthe coils are over an inch diameter?
Old May 18, 2005 | 06:07 PM
  #25
Robinhood150's Avatar
Thanks, that helps a lot.
So you're saying the tailgate sags 2 inches when you sit on it? Wow.
Old May 18, 2005 | 07:23 PM
  #26
KevyWevy's Avatar
hahahahaha OOOOOPPPS!!!! its 15mm i don't know why i wrote down 3cm???!!!!
yeah, essentially 2" but im fat. 200 on the end of the tail gate. stock rear bumper and all that goodness.
Old May 18, 2005 | 07:54 PM
  #27
yotaman's Avatar
I have FJ80 Coils and when I sit on the tailgate the rear doesn't move much. I weight about 185. I’ll measure tomorrow. My rear sits higher than the front and I’m 16.5 rim to fender up front.
Old Aug 8, 2005 | 09:22 PM
  #28
Update.
I picked up some 93 rear coils and took some measurements. The numbers actually don't say much, infact they're pretty close.
....................Wire dia........Wire dia.......Wire dia......Wire dia.......Overall
Spring..........Bot (mm).....CTR (mm)....Top (mm)....Ave (mm)....Length (cm)
97 LX long......15.28...........15.23...........15.21... ......15.24.............47.5
97 LX short.....14.94...........14.86...........14.85... ......14.88.............45.3
93 LC-1..........15.42...........15.32...........15.36.. .......15.37.............48.3
93 LC-2..........15.50...........15.47...........15.44.. .......14.47.............47.5
The only obvious difference I see is that the 93 LC coils have a shaved, flat top while the LX coils just end, as you can see from this picture
(The springs are lined up with the concrete crack and the measuring tape shows the difference in height. LC coils on left, LX coils on right)
So what did I find out? Well I threw the 93 LC coils on the 4runner fully expecting to have the same height as LX coils, but to my surprise I found I had gained 1 inch in height. That's what I was looking for all along. I've even put on about 400 miles with a trip to pismo dunes...same height now.
So in summary, the dimensions are similar but the way the spring terminates is different. The LC coils gave me 1" more lift than the LX coils. If you want less lift than the normal cruiser coil swap, try the lexus springs. In my case, the heavy rear bumper really brought things down and I needed the extra lift of the land cruiser coils.
Old Aug 9, 2005 | 10:42 AM
  #29
99_Runner's Avatar
Got any pics with the Land Cruiser coils installed?
Old Aug 10, 2005 | 02:13 PM
  #30
PAhydrohead's Avatar
I do. Go to post #43 in the following thread https://www.yotatech.com/forums/show...9&page=2&pp=25 Pics were before I added the 1.25" body lift.
Old Aug 10, 2005 | 07:03 PM
  #31
s_wall98's Avatar
Heres some more.
Before with 32s:
After cruiser coils and bj spacers
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
the_supernerd
Oct 1, 2015 09:20 PM
4runnerFireman
Sep 29, 2015 06:24 AM
justdifferentials
Sep 5, 2015 06:52 PM
