suzuki guy needs toyota guys help
Old May 16, 2006 | 01:26 PM
tech's Avatar
first off, hello everyone. i spend most of my time at the zuwharrie.com forum but the guys over there have limited toyota knowledge. i'm building a 2-door sidekick on toyota axles and i'm wondering what wheels i can steal off of another truck that will give me a little more offset.
example: if you want some offset wheels on a suzuki then you can just get some bronco wheels and they fit perfect.
Old May 16, 2006 | 01:38 PM
Tacoclimber's Avatar
Depending on the center holes, some chevy rims can work, but I would stick to Toy rims. Just check the backspacing on them, if you're going for more offset, look for less backspacing.
Old May 16, 2006 | 01:39 PM
AH64ID's Avatar
Dont see too many people here run wheels from other makes, usually OEM or aftermarket..
Old May 16, 2006 | 02:07 PM
deathrunner's Avatar
I think Dodge Dakota rims would fit. Not 100% sure though.
Old May 16, 2006 | 02:10 PM
TEPUI's Avatar
tech,
Most Japanese 4x4s use the same lug pattern (6 on 5.5) as Toyota: Nissan, Mitsubishi, Isuzu.... also some Chevys: Tahoes, Suburban, Blazer, K5, and some of the old J**p Wagoneer, Honchos, etc. So if you're looking for a good deal from a junk yard or newspaper ad your choices are pretty broad. OEM wheels probably wont give you that much offset, but again, a zuk with toy axles gets a pretty wide stance so your wheels will stick out even with 7 or 8 inch wheels.
BTW: I wouldnt steal them
Old May 16, 2006 | 02:11 PM
TEPUI's Avatar
I am almost positive Dodge Dakotas use 6 on 4.5, not 6 on 5.5 like Toys.
Old May 16, 2006 | 02:21 PM
tech's Avatar
thanks for the help guys
i've got some other questions that i will make a new post for.
Old May 16, 2006 | 11:11 PM
sorry, just a thought
Old Jun 7, 2006 | 11:05 PM
mikevyota's Avatar
Dakota wheels are 6x4.5, so they won't work with the toy axles. Also, watch some of the chevy wheels. Some, like the steel "rally" wheels or earlt centerlnes won't clear the calipers of early, solid front ends. My steelies from discount tire were cheap( $46 each for 15x10) and clear great. Sami's are great, my brother's follows my 82 pu everywere. Put some power into the, like a rotary swap, and they are killer.
Old Jun 11, 2006 | 07:39 PM
TX-BLKRUNNER's Avatar
the new GM wheels will not work because the center bore is too small, i think the old k5 era will work though, also nissans have the same pattern and same center bore. good luck
Aleeex_u
Jun 5, 2016 06:52 PM
slider417
Jun 22, 2015 10:18 AM
UKMyers
11
Jun 24, 2002 05:41 AM
