Rubicon Express vs. Johnny Joints??
Old Oct 31, 2004 | 08:19 AM
ravencr's Avatar
Does anyone know which is better or has more flex?
Chris
Old Oct 31, 2004 | 01:24 PM
ravencr's Avatar
Anyone?
Old Oct 31, 2004 | 01:31 PM
Bighead's Avatar
Schaefer put Currie Johnny Joints on his Spidertrax rear lower control arms so he may be able to give you some insight on those. Doesn't Rubicon Express use heims?
Old Oct 31, 2004 | 01:48 PM
anestech*'s Avatar
I believe they have similar degrees of articulation, but the Currie ones will last a lot longer, and will not clunk like the RE ones are prone to. I speaking from experience with numerous jeeps with RE stuff and others that use Clayton's Long Arms with Currie ones.
John Currie invented the Johnny Joint (hence the name) and he knows his stuff.
Old Oct 31, 2004 | 02:23 PM
ravencr's Avatar
That's what I wanted to know! They appeared to be the same type of joint, so knowing that one is a lot more durable is exactly what I was looking for.
Spidertrax appears to use the RE joints and not the Johnny Joints, but the guys above said he used the Johnnyj joints. I wonder if they do both??
Chris
Old Oct 31, 2004 | 04:31 PM
Flygtenstein's Avatar
I have RE joints on my lower control arms.
They are greasable and apparently more easily rebuildable.
In the end though, they are darn close in cost and performace as well as longevity.
Old Oct 31, 2004 | 05:26 PM
Bighead's Avatar
As far as I know the Spidertrax arms still come with heims. From what I understand, Steve swapped his out because the original heims were wearing out and he wanted something different.
Old Oct 31, 2004 | 05:54 PM
BruceTS's Avatar
The problem with running the 3/4-16 Johnny Joint assembly is the diameter of the connecting bolt being 7/16 and if you use either weld-on assembly, you'll need to make the links to the exact length. There is no ability to do any kind of adjustment if your alignment is off.
The RE joints are easier to service, the JJ's are a PITA to assemble unless you have a press.
Old Oct 31, 2004 | 06:03 PM
ravencr's Avatar
Bruce, do you think the RE joints are as strong and durable as the JJ's? I know whan I did my JJ's, like you said, they require a press to assemble. It was a pain.
Chris
Old Oct 31, 2004 | 06:19 PM
My arms are Spidertrax, they will make links just about any way you want them.
Bruce, I am glad to hear echoing of my impression the RE's are easier to service and assemble.
Old Oct 31, 2004 | 06:49 PM
BruceTS's Avatar
When I did my research in making my rear links, I took all 3 joint designs into consideration. The RE's are a better choice, but since I wanted the ability to fine tune my suspension neither would fulfill my needs. I ended up getting these;
The HRSMX12T Series, FK Rod Ends with Teflon Liner, since my lower links will be made to endure hard hits against the rocks, I wanted 3/4" F911 grade connecting bolts, the JJ's use a 7/16" and the RE's use a 9/16" bolt. The Teflon liners don't need any lubrication, in fact if you did, they cause premature failure.
Old Nov 1, 2004 | 01:23 AM
ravencr's Avatar
Did you use them at both ends, Bruce?
Chris
Old Nov 1, 2004 | 06:15 AM
I had forgotten the hardware dimensional difference.
I have teflon lined Aurora's on mine.
If a person builds and mocks up before specing final links, joint selection is somewhat less critical, but as you said, the RE joints that weld on have no practical adjustment once they are burned on.
What about the notion that the RE will give some on a hit while a heim will transmit the hit to the link and the frame since there is less (no?) give.
Old Nov 1, 2004 | 12:15 PM
BruceTS's Avatar
When I build my mounts, the heim joints will be protected from direct contact with the rocks. I doubt I'll ever slam the links against the rocks hard enough to break one of the rod ends. On the JJ's I'd be afraid or the wimpy 7/16" bolt shearing off. The JJ's will give more than the RE's and the heims don't give at all, but since the frame is isolated from the cab by rubber mounts there is little to no additional transmission of road noise.
Old Nov 3, 2004 | 01:54 AM
ravencr's Avatar
So, if I knew the exact length of my bars, then the weld on RE's might be the best thing, right?
Chris
Old Nov 3, 2004 | 07:36 AM
Not sure if I am on ignore or what.
What Bruce means is with the heims, you can adjust rotational alignment for the ends with the links. I mentioned mocking up the links and then burning on the RE joints earlier, but they have not rotational adjustment once they are on. You have to be sure the hole is in the right plane so there is no binding.
Old Nov 3, 2004 | 09:03 AM
ravencr's Avatar
Cool deal! I understand now! I appreciate it guys!
Chris
Old Nov 8, 2004 | 04:46 PM
ravencr's Avatar
I was at Tellico this weekend, and I saw some seriously cool suspension setups, and I'm wondering where people are buying all these different types of joints, & spindle looking swivel mounts, etc. Does anyone know where to find these items?
Chris
Old Nov 8, 2004 | 05:09 PM
Check Spidertrax.
Check the PBB vendor section, lots of shops with links, link material and joints.
Old Nov 8, 2004 | 05:16 PM
ravencr's Avatar
Have you ever seen the gigantor pics? I'm wanting to do something similar, because it seems he has the most flex I've ever seen.
Chris
