Reservoir shocks on a 2nd Gen 4Runner
Old Dec 7, 2006 | 09:34 AM
Sweep's Avatar
Wow, I rock the double post.....
Old Dec 7, 2006 | 09:40 AM
Sweep's Avatar
Blizzard,
do you know the part number for the shock you are using in the front. I am pretty sure that there is a correct resivior shock for fittment in the rear of your rig. The front is what will need the most work if any. Or on the fronts could you pull one and do a full compress / extend and give some dimensions?
That Fox shock specified as (rear) may fit on the front of your rig if it came with the right valving.
Old Dec 7, 2006 | 09:44 AM
Blizzard's Avatar
Yes, I've the OME N72F's in front and Rancho RS99251 in the rear.
The rear don't worry me as much as the front as I always can put a limiting strap or something.
I don't have the front measurings, the rear ones are a bit longer than the popular 9009's or 5009's and the sizes can be found on the Rancho literature.
David
Old Dec 7, 2006 | 09:49 AM
Sweep's Avatar
The ARB site dosen't seem to have the shock specs on it anymore. I am not sure what to tell you without that measurement.
Old Dec 7, 2006 | 01:01 PM
  #25
ewong's Avatar
From what I can tell up front you have
-- ball joint spacers
-- thinner bump stops (but on the OEM bracket)
Im gonna make a guess that the shock is in fact a stock shock (in terms of travel - not damping)...
I'll have to go look stuff up...
Old Dec 7, 2006 | 02:08 PM
  #26
SAS'dToy's Avatar
Sway-a-way makes nice ones too...
Old Dec 11, 2006 | 11:13 AM
  #27
Sweep's Avatar
any luck sourcing your shocks?
Old Dec 11, 2006 | 11:24 AM
  #28
Blizzard's Avatar
I've had no time to look at...
I'll try to do it soon hehe
Thanks for your interest,
David
Old Dec 12, 2006 | 01:10 AM
  #29
Blizzard's Avatar
I've the front OME sizes:
Extended: 15.30''
Compressed: 9.80''
And my rear Ranchos are:
Extended: 27.00''
Compressed: 16.125''
I'll try to search suitable shocks as soon as I've some free time hehe
David
Old Dec 12, 2006 | 01:15 AM
  #30
Blizzard's Avatar
Well, in Fox I could get the 2.0 x 5/8 Remote Reservoir for the rear:
Extended: 26.10''
Compressed: 16.10''
I'll have to use a stud-to-eye braket and maybe put a little spacer on the bumpstop as my curren Ranchos are very close to bottom.
Maybe those will work for the front, but they marked as "Rear"
Extended: 15.65"
Compressed: 10.65"
They're a bit longer in compression, but I don't know if my OME's can still compress more or not... I also have low profile compression bumpstops so this is a problem.
http://offroadwarehouse.com/Store_Vi...p!ProdID!15010
David
Old Dec 12, 2006 | 04:23 PM
  #31
ewong's Avatar
Rancho Site with Shock specs
http://www.gorancho.com/flash/docs/2...ifications.pdf
Looks upt to a RS5145
9.37 compressed
13.375 extended
See page 14 on this link
http://www.bilstein.com/motorsports_cat.pdf
Has the right travel but isnt remote res...
Its beginning to sound like a $$$ solution is the only way out.
Old Dec 12, 2006 | 11:50 PM
  #32
Blizzard's Avatar
Yep... I think I'll stick with OME and change them more often with the difference of $$$.
I know it's not the same but (If I don't win the lottery) I would be only going to the desert once a year...
Thanks for your input,
David
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
