Regearing requires new locker?
Old Mar 3, 2004 | 07:19 PM
Mad Chemist's Avatar
Just wondering...I'm planning out mods for my FJ-40. Its likely that I'll get a locker installed in the rear initially. At some later date after taking care of a few "other" things I'll be upgrading to bigger tires and will be regearing. I'm thinking that the lockers are independent of the gear ratio, but I'd like some confirmation thats the case.
Old Mar 3, 2004 | 08:22 PM
toy283's Avatar
Yes. The lockers and the gears are two entirely different things. It is usually best to do both at the same time to save on labor costs but they can be done separately as well.
Old Mar 3, 2004 | 09:03 PM
Flygtenstein's Avatar
Doesn't the difference arise on some Dana axles where you need a X.XX ratio and up or X.XX ratio and down carrier/locker for thin or thick gears?
How wide is the front axle on a 40?
Old Mar 3, 2004 | 10:27 PM
Napoleon047's Avatar
its the same width as a mini but with narrower perches and a different diff
Old Mar 4, 2004 | 05:58 AM
Jake, you are a lucky man!
When looking around for a Powertrax Lockright, there's just one listed for the stock axles, which to me indicated it didn't matter what the gearing looked like in side for the stock housing.
Old Mar 4, 2004 | 11:56 AM
toy283's Avatar
No difference in Cruiser diffs as long as the year & model are right. There were different differentials used in different Cruisers but mostly overseas. AFAIK FJ40, FJ60, and FJ80 rears are all the same, front FJ80's can be different.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
Iceman4193
Oct 16, 2015 10:50 AM
Truckwithoutaname
Oct 3, 2015 03:41 PM
charlie_fong
Sep 27, 2015 10:06 PM
