Rear lift springs?
Old Nov 15, 2003 | 10:35 AM
From: Williamsport, PA at school - Elverson, PA at home
Rear lift springs?
I drive an xcab 93 sr5 v6 4x4 pickup, lifted 4" susp. with a pro-comp stage II kit and 2" body.
The rear susp. currently has the 3.5" tapered pro-comp block and a pro comp 13120 add-a-leaf
I currently have an axle-wrap-of-death problem and am deathly afraid soon I am going to snap the pinion off...
I have been looking at rear lift springs recently, skyjacker and NWOR seem to be all I can find. Can someone recommend other manufacturers? What should I expect to pay?
Thanks for any and all help!
Old Nov 15, 2003 | 11:32 AM
joez's Avatar
all pro. they may be more expensive, and require welding, but will ride better, flex better, and have much less axlewrap. or there are always alcans.
head to your local spring shop, and see what they will fab up for you. they will make it to your needs.
Old Nov 15, 2003 | 12:11 PM
Thanks for the advice, I filled out the quote form on Alcan's site. Gonna check with all-pro in a few minutes, monday I'll check the spring shop here in town
-Will
Old Nov 15, 2003 | 01:27 PM
oly884's Avatar
Guest
If I were you, I'd go with the all pro. I have the skyjacker springs in the rear, and they suck. My passenger side is sagging about 1.5 to 2 inches. It sucks.
Old Nov 15, 2003 | 01:36 PM
its2slo's Avatar
alcans will run you $410. tom is a great guy to work with..
I was sorta leary of the skyjacker thing, they never seemed like a "top of the line" company, when it comes to safety on a road going vehicle, that seems important to me. Anyway, since we are running nearly identical trucks (mechanicaly), did you have an axle wrap issue running the pro comp blocks?
Just curious
Will
Old Nov 15, 2003 | 01:44 PM
Thanks its2slo, I like hearing from people who've had positive experiences with vendors
-Will
Old Nov 15, 2003 | 01:55 PM
oly884's Avatar
Guest
Just curious
Will
I did have horrible axle wrap issues. It's gone now, but the sagging passenger side drives me crazy. I think I might go with the alcans, but I'm not 100% sure, the all pro's sound appealing.
Old Nov 15, 2003 | 01:59 PM
its2slo's Avatar
one thing i liked (not to mention the quality) was how he took my custom order, gave me a time frame, and said hed call when they were ready.....no money down!! nothing like doing business on a handshake.
Old Nov 15, 2003 | 02:08 PM
Awesome, thanks for the replies so far guys, really appreciate the advice! Anyone else with experience, please feel free to chime in with opinions!
-Will
Old Nov 15, 2003 | 02:11 PM
since so far, we all seem to be runnin similar trucks, I want to ask a REALLY stupid question, doing the standard jack up the rear, spin the tire and watch the driveshaft, my calculations come out showing a stock gear ratio of somewhere around 4.10, can anyone confirm that?
Old Nov 15, 2003 | 02:14 PM
oly884's Avatar
Guest
Is it manual or auto? If it's manual, and I see that you have the V-6, you should have 4.56's. At least that's what I have on my truck.
Old Nov 15, 2003 | 02:27 PM
After I asked, I did a search on the net, then ran out to check my axle code. Sure enough, my 5 speed equipped truck has 4.56 gears... makes 4.88s seem kind of a waste of money...
Old Nov 15, 2003 | 03:28 PM
oly884's Avatar
Guest
Yeah, to be honest, with the V-6 you don't really need 4.88's with 33's. I don't have much of a problem getting around.
Old Nov 15, 2003 | 03:35 PM
Hmm, your truck must run better than mine! plus, I go to school in the mountains, and third gear trying to run 45mph up steep hills sucks...
Old Nov 15, 2003 | 04:09 PM
oly884's Avatar
Guest
Well, my truck isn't running THAT good. Up steep hills I can keep it at about 50-55, that also depends on altitude, weather, wind, etc. Going back to my home in Seattle I cross a few passes that are close to the 7,000 ft mark. You definetely notice the difference in power when compaired to sea level.
Old Nov 15, 2003 | 09:19 PM
My situation right now is that I have the room to run 35s, but I wouldn't even try to turn them with the stock gears. I figure 4.88s put me just over stock effective ratio, but with 35s in the near future, I am starting to think something steeper would be wise, maybe 5.17s or even right to 5.29s
5.17s would put me right at stock effective with a 35" tall tire. If I knew the 35s were going on immediately after the gear swap I'd just go right to 5.29s, just afraid of going too drastic and killing the tiny little bit of top end I have.
-Will
Old Nov 15, 2003 | 09:37 PM
Shane's Avatar
Agreed. I have a pair of 2" Alcan springs on my truck right now that are about 3 years old with no problems, and I've got a full 5" set front and rear sitting in the garage waiting to be installed next weekend. They're pricy, but they work and they'll build them to your specs. Anything you could ask for they can make.
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
coffey50
Jul 28, 2015 10:55 AM
Nickdigg
Jul 7, 2015 06:04 AM
