preventative maintenance while installing lift?
Old Feb 15, 2010 | 05:31 PM
Dmanflynn's Avatar
I bought a 1993 yota pickup single cab 22re 4wd about a week ago. It came with 31/10.50's. However, he did not lift it any so when you crank the wheels left or right pretty far it hits the pinch weld and fender well. I can drive it without hitting it but if I scew up and crank it hard it just gets worse. My goal is to buy a 2" lift which should clear it just fine and make it look clean. However since there is such a wealth of info on this site on toyotas and the people who modify them, I have a question as to what I might want to replace if I go ahead and put a lift on. In other words, If im going to take crap apart, is there anything that I need to watch for that might be worth replacing while its all apart? Its got 190,000 but the guy had the engine rebuilt and a new clutch installed but as to that nothing else was replaced. Im just thinking that Id like to replace a few things while I have it up and apart like brakes or anything else that would be good preventative maintenance.
Attached Thumbnails preventative maintenance while installing lift?-my-truck.jpg   preventative maintenance while installing lift?-my-truck2.jpg   preventative maintenance while installing lift?-my-truck3.jpg
Old Feb 15, 2010 | 05:48 PM
Blue Bowtie's Avatar
A rebuilt engine at 190,000? Something doesn't sound right about that.
Anyway, check your ball joints, tie rods, brakes, swaybar end links, u-joints, etc.
Old Feb 15, 2010 | 05:57 PM
Dmanflynn's Avatar
I knew the guy from an engine shop in town. He rebuilt it an replaced a few things. I talked to him about it and it was more for resale than anything else so I dont think theres too much to worry about. But I will check those things mentioned above. I plan on a toytec 2 inch lift kit. Rear add-a-leafs+extended shocks and spacers in the front.
Old Feb 15, 2010 | 05:59 PM
4banginRunner's Avatar
The 31s rub because of your backspacing wheels.......
33s fit fine on stock 3rd gens
Old Feb 15, 2010 | 06:02 PM
Teuf's Avatar
I would guess that BJ spacers and a longer shackle would give you enough lift aye?
Old Feb 15, 2010 | 06:12 PM
Dmanflynn's Avatar
Explain what you mean by my wheels backspacing. And I think the spacers would work in the front for sure but I want it to set even so I might as well get matching leaf lifts no? Help me out here guys Im new to the business.
Old Feb 15, 2010 | 06:21 PM
The wheels stick out to much, get different rims with a numerically higher backspacing which will suck the tires under the truck more...making a factory tire size..not rub.
Old Feb 15, 2010 | 06:24 PM
Teuf's Avatar
Add A Leaf? In the rear.
Old Feb 15, 2010 | 06:31 PM
Dmanflynn's Avatar
@4banginRunner, Let me ask you this, plainly, will a 2" lift kit fix the problem or are the tires still going to be too wide? If it will fix it Im going to install it.
Old Feb 15, 2010 | 06:38 PM
Teuf's Avatar
Is it me or do those tires look bigger than 31's.
Old Feb 15, 2010 | 07:09 PM
2DoorRunner's Avatar
i think its the black wheels that make them look bigger. The same thing happens with my 4runner.
Old Feb 15, 2010 | 07:22 PM
Teuf's Avatar
Ah OK i can see that in my minds eye, Ayup.
Old Feb 16, 2010 | 02:45 AM
Possibly, I've never ran wheels with that kind of backspacing. I just dont see the point in lifting it just to clear a factory tire size, when you can get new or even stock wheels and run what you have
Old Feb 16, 2010 | 07:16 AM
Dmanflynn's Avatar
I appreciate all the info, but right now, I prefer lifting as I would like the way it looked better too. What preventative maintenance was needed to look for was what I needed and I think I have that. Thats all I needed to know as of yet. Thanks
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
PlayAwhile
Jul 20, 2015 11:36 AM
