pp springs/285/75/16
Old Nov 29, 2006 | 06:46 PM
deaddrifter's Avatar
whats up guys i have a 99 sr5 sport with the performance products 1" spring and billstein front and back, it is closer to 2" though, can i put the 285's on ? thanks alot.
Old Nov 29, 2006 | 09:46 PM
AH64ID's Avatar
Run a search and see what others are doing.. it also really depends on what you use it for, if you are offroad a lot where you articulate a ton then they will rub, but if you have a street queen you should be fine... A lift like you have raises the ride height, but doesnt change the room for tires, if you wheel and articulate the suspension..
