OME suspension scew-up...please help
Old May 11, 2005 | 05:50 AM
chas4runner's Avatar
Mick -
Already have the OME front coils. The problem is the cup is welded on down on the stock strut. Are they any other options besides ordering OME shock/struts?
Thanks
Old May 11, 2005 | 05:56 AM
Mickdady's Avatar
I am confused. I think I need a picture. This doesn't make sense.
Compare this to what you have then reply back with what is wrong
http://www.drawhorn.org/front_ome_install_writeup.htm
Old May 11, 2005 | 06:04 AM
Mickdady's Avatar
I just went out and snapped some pics of mine. Hope this helps.
Old May 11, 2005 | 07:33 AM
BajaRunner's Avatar
Chas:
I didn't know you were using the stock shock. They cant screw that up because it is welded on.
Its recommended that you use the OME front shock with the lift coils because it is a lot longer than the stock one.
You could also use some bilstiens if you want.
Old May 11, 2005 | 08:20 AM
  #25
Gosh - I hope blisteins are cheaper than OMEs
Old May 13, 2005 | 05:13 AM
  #26
Hey guys -
I'm going to go ahead and order some OMEs shocks for the front...Which part # would go well with the 880 coil springs? I am running 890's in the back so I'm hoping to level out the dragster look when I install the shocks.
Anyone running 880s in the front and 890s in the back? Any sag in the front? Did you have to add a spacer in the front?
Thanks - Hopefully I will get it right this time
Old May 13, 2005 | 05:15 AM
  #27
Sorry 1996 4runner Limited
890s on the back
880s on the front
265/70/R16 Duelers
Old May 13, 2005 | 08:23 AM
  #28
Albuquerque Jim's Avatar
Originally Posted by chas4runner
Hey guys -
Old Man Emu HD N91S firm front shocks
IIRC, you will still need to either add a 1" inside the pack spacer or add at least 1 top out spacer to make it level (probably 2).
Old May 25, 2005 | 10:56 AM
  #29
UPDATE - I installed the OME880s with 5MM trim packers and N91SC's. The truck still sits a good 1-1.5 inches higher in the back. I'm gonna stick my boat the back a few nights. Hopefully it will settle out some. I didn't go with spacers this time, but that may be an option. I do some traveling and didn't want a harsh ride.
Question...Would the TRD Tundra coils give you a 1.5 inch lift? I may should've gone with that. I still need to order shocks for the back. However, I'm not going with OME, most likely Bilsteins BE5-2451's
Old May 25, 2005 | 12:08 PM
  #30
bamachem's Avatar
actually, you should get the OME shocks for the back and the tundra coils + spacers for the front and you'll sit level.
ZGjethro
Jun 7, 2017 11:04 PM
live4soccer7
May 11, 2016 06:52 PM
A2theK
Oct 14, 2015 07:10 AM
ktm192k
Oct 1, 2015 08:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
