OME 860's on the way!!
Old Mar 2, 2004 | 01:36 PM
Mikronized's Avatar
I just ordered my OME 860 5.5" rear lift coils! I'm so stoked.
they should be here next week so I'll post pics then.
Old Mar 2, 2004 | 03:37 PM
anthony1's Avatar
so you don't like the ones that came with the lift kit eh?
I have OME 863. It's pretty high.
http://home.earthlink.net/~audiorat1...s/rearsu~1.jpg
I used both Downey and AllPro pan hard rod drop/raised.
Old Mar 2, 2004 | 09:16 PM
Mikronized's Avatar
yeah... the superlift coils that came with the kit never leveled it from the start, and now the coils have sagged... so the rear end is about 2" lower then the front.. so I figure the 5-5.5 inch rear lift should be fairly level with just a bit of T-bar adjustment.
as far as panhard stuff goes, I've got the good-sized superlift drop bracket and we'll see how much more I need.. the superlift bracket and the allpro lift would make for too much so I might just get an adjustable panhard rod..
I'll let you know.
[edit]
did you need to have the rear driveshaft lengthened? I've heard some people having problems when using 5+ inchs of rear lift.
Old Mar 3, 2004 | 08:01 AM
anthony1's Avatar
I had to go to the junk yard and get pre 86's front d-shaft with cv in it. Basically, there's an extra ujoint in there. It suppose to reduce vibration and stuff. I can hear the loudest when I'm coasting. I didn't know what it was first, I thought my trans was going but one call to Marlin, he told me it's the d-shaft.
Old Mar 3, 2004 | 09:48 AM
Mikronized's Avatar
I might just put in a double carden joint in then.
Old Mar 4, 2004 | 07:13 AM
Stump1883's Avatar
Just go with rear leaf springs, you'll never get coil springs to stop sagging, they'll always wear out faster and loose lift before leafs Why Switch to Rear Leafs??? 1/2 way down the page . Good luck, hope the OME's work out for ya, post some pics your rig is gona be HUGE.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
A2theK
Oct 14, 2015 07:10 AM
Swampwalker
Oct 12, 2015 09:49 AM
justdifferentials
Sep 5, 2015 06:52 PM
