Mystery picture
Old Oct 5, 2014 | 09:20 AM
ChristopherRobin's Avatar
Mystery picture
What all is wrong in this picture? Thanks for the input!
Old Oct 5, 2014 | 11:26 AM
nothingbetter's Avatar
Is this a test? Post another picture beside it so we can play the "spot the 10 differences game"
your running bfg tires. Theres your biggest problem
you still have an LSPV? ditch it and get an manual valve.
Old Oct 5, 2014 | 11:47 AM
JasonYota's Avatar
No tailpipe, no spare tire, lift blocks
Old Oct 5, 2014 | 12:57 PM
morena67's Avatar
...Nothingbetter ...Actually the LSPV is cancelled, since you can see the position arm disconnected...
So... ChristopherRobyn...the mistery continues...?
Old Oct 5, 2014 | 12:58 PM
morena67's Avatar
Oh...is that what is wrong...? Cause the lines are still connected...
Old Oct 5, 2014 | 02:05 PM
the 1" of available rear travel before your bump stop hits?
Old Oct 5, 2014 | 02:26 PM
vital22re's Avatar
totally a bro
inverted leafs
Old Oct 5, 2014 | 02:31 PM
morena67's Avatar
...Looks like the picture was taken while flexing the truck...?
Old Oct 5, 2014 | 02:46 PM
dropzone's Avatar
Fossilized
The LSPV rod is just wedged over the exhaust hanger at least zip tie it or get the rod mounting bracket for the axle
Or you are lost in the 100 acre Woods
Old Oct 5, 2014 | 03:50 PM
Honestly, I posted the picture not knowing what the heck is wrong.
1st whats the lspv?
2nd it's slightly flexed so I could take pic
3rd are the brake cables on the correct side of the springs?
Old Oct 5, 2014 | 04:19 PM
JasonYota's Avatar
Originally Posted by ChristopherRobin
Honestly, I posted the picture not knowing what the heck is wrong. 1st whats the lspv? 2nd it's slightly flexed so I could take pic 3rd are the brake cables on the correct side of the springs?
What problem are you having that you think something is wrong??
Old Oct 5, 2014 | 07:19 PM
toyota4x4907's Avatar
Driveshaft hitting the gas tank.
Old Oct 6, 2014 | 10:47 AM
Is it hurting anything like it is? I'm not familiar with yota s or LSPV.
Also. Shouldn't those brake cables be under the leaf springs?
Old Oct 7, 2014 | 08:08 AM
dropzone's Avatar
Fossilized
The rod being up like that is pretty common, it biases more fluid to your rear brakes.
Rear hydraulic brake lines are where they should be.
Your parking brake cables have to run above the springs due to the location of the pivot points
Old Oct 7, 2014 | 08:16 AM
highonpottery's Avatar
what is your actual question regarding your rig? sounds like you just need to do your homework on how your Toyota is designed
Old Oct 7, 2014 | 09:05 AM
Thanks dropzone.
Highonpottey, thanks for being such a ray of sunshine.
Old Oct 7, 2014 | 09:41 AM
JasonYota's Avatar
Thanks dropzone. Highonpottey, thanks for being such a ray of sunshine.
You have been asked twice what do you think is wrong yet you do not answer.
Might as well post a picture and ask where's Waldo…
Old Oct 7, 2014 | 10:23 AM
1st whats the lspv?
Jason yota,
I thought this was where I asked my question/stated my problem (thread post #10). Next time I will try to be more clear.
Old Oct 7, 2014 | 10:37 AM
RAD4Runner's Avatar
Yes, You absolutely have rear sag. Blocks only improve ground clearance but not ride quality. I bet that truck has to slow down at every little dip on the road; something a real off-road vehicle should not have to do.
Search "Rear Sag", "Zuk", "OME".
Old Oct 7, 2014 | 10:41 AM
open up google and type in "toyota lspv pickup" that will explain what it is.
I prefer my brake lines over the springs, keeps them a bit more protected from rocks, stumps and other nasties.
Bourbonblues
Dec 15, 2017 05:43 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
carid
Vendor Advertising
Sep 10, 2015 06:11 AM
