My new AW shifter
Old Aug 25, 2008 | 04:41 PM
R.DesJardin's Avatar
My new AW shifter
Needed a way to shift my AW, didn't want to buy what was available so I made my own. The first one was using a Omron PLC(Programmable Logic Controller) it worked great, I had switches mounted on the steering wheel.
I got to thinking that since you are only controlling two solenoids the PLC seemed overkill. My first thought was a lever that had notches on a radius to turn micro switches on and off at the right time. Lots of machine time involved with that idea so I moved onto a rod with notches for the micro switches, two aluminum blocks machined that fit together with a Z/S gate pattern on the top. Tada shifter, finished size is 3/4" x 2" x3" long.
Mounted in the center console area. Added a separate switch for TC lock up and now no computer needed. Simple and easy to make.
Old Aug 25, 2008 | 04:51 PM
Hayes's Avatar
where do you connect it to? What was the total cost? How much would you sell one for?
Old Aug 25, 2008 | 05:21 PM
Godzilla's Avatar
http://radesignsproducts.com/default.aspx
Old Aug 25, 2008 | 05:29 PM
yotasavg's Avatar
that's really cool. so you can basically control an A340 much like a tip-tronic setup?
Old Aug 26, 2008 | 11:25 AM
Rail Shifter
Yes you can shift your auto, 1-4 with just this unit connected to solenoid wiring from transmission. Very simple and didn't cost a lot to make.
Old Aug 26, 2008 | 01:35 PM
Hayes's Avatar
I didn't see a cost...
Old Aug 26, 2008 | 06:06 PM
Godzilla's Avatar
I think it is the 80.00 in red lettering
Old Aug 26, 2008 | 07:17 PM
Hayes's Avatar
yeah, I missed that completely on the first round.
Old Sep 15, 2008 | 02:59 PM
Hayes's Avatar
can someone please explain TC lockup to me?
Old Sep 15, 2008 | 05:25 PM
Godzilla's Avatar
I searched for this ages ago and I cant remember the results in detail enough to comment on, but there is tonnes of readings and explanations on when to use TC lockup with your overdrive button and such. Use the search words ECT and overdrive ..you should get plenty of reading.
Old Sep 15, 2008 | 08:26 PM
Lockup
Let me try and feel free to correct me. Readers Digest version: The lockup is the torque converter actually locking directly to the trans thus eliminating slippage and lowering engine rpm. If you could stop with converter locked the engine would stall.
Old Sep 26, 2009 | 03:26 PM
whokrz's Avatar
Are you still working on a mechanical / electric shifter that will replace the factory mechanical shifter and still have manual control of 1-4 shifting.
My girlfriend and I are slowly building a 1990 4runner with a 22re and are planing on swapping in a A340/4.7 gear driven case. We paid awshifting for a shifter but they seemed to have vanished. So we still are in need of a way to shift the transmission and it sounds like you are working on a nice version of what we need. Do you have any teaser pictures?
mwisham
May 26, 2021 02:51 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
irv
Sep 22, 2015 11:51 AM
briholt
Sep 20, 2015 10:26 PM
eggens
Sep 5, 2015 12:16 AM
