Marlin Crawler Box (2.28 and 2.28)
Old Nov 25, 2008 | 08:42 PM
89silverpu's Avatar
So I have been looking into getting 4.7 gears to put in my t-case, but while looking at Marlin's website, I saw that they had crawler boxes ready to put in between the tranny and the t-case for dual cases. I have two questions:
1. Does having dual 2.28 cases give you an overall t-case gear ratio of ~5.2:1 in double low? or what is it??
2. How much is it to get the drive shaft modified/shortened?
Thanks!
Old Nov 26, 2008 | 07:40 AM
AxleIke's Avatar
1. Yes it does.
2. Shafts. Both need to be done. Mine were about 250 out the door, but I had them retubed, since the stock ones are paper thin. That was from a local shop. Call around and see what people can do for you.
Old Nov 26, 2008 | 07:52 AM
tc's Avatar
tc
x2 for AxleIke's post
Old Nov 26, 2008 | 08:15 AM
jmazoso's Avatar
When I did mine the shafts changed by about 4.5 inches.
I love having the dual cases. You endup with three forward speeds
1:1, 1:2.28, and 1:5.2 plus you get a 1:2.28 in 2wd
If you need more gear, you can always change the rear case to 4.7
gears in the future, and have 4 forward gears.
Old Nov 26, 2008 | 09:38 AM
AxleIke's Avatar
4 forward gears is the bomb.
I run 2.28 for snow, and easy fire roads. I run 4.7 on the difficult trails, in between the obstacles. and I run 10.7 on the obstacles. Having choices is good.
Old Nov 26, 2008 | 10:45 AM
89silverpu's Avatar
Thanks! I'm assuming a new crossmember would be in order as well? A budbuilt for instance...?
Old Nov 26, 2008 | 10:50 AM
64-Hurricane's Avatar
You are correct sir. New X member, floor board modification, top shift. etc..
89silverpu's Avatar
Old Nov 26, 2008 | 01:20 PM
tc's Avatar
tc
You can run the stock crossmember, but that's a lot of torque on the one tranny mount. A dual-case crossmember (like Budbuilt) with 2 tranny mounts or the FROR crossmember are highly recommended.
If you go with a clocked adapter, you have to use the FROR crossmember to realize the ground clearance savings.
Old Nov 26, 2008 | 01:34 PM
89silverpu's Avatar
Thanks! Good to know, I was wanting to get a Budbuilt anyways for added ground clearance because the stock crossmember is like a plow lol
Would I have to do anything to my stock t-case? Would I just put the crawl box in between the t-case and tranny and go from there?
Old Nov 27, 2008 | 07:17 AM
tc's Avatar
tc
I don't know - mine was already assembled. I think there's an instruction sheet on the marlin website.
Old Nov 27, 2008 | 09:42 AM
AxleIke's Avatar
Unless you are putting in a twin stick, no. Just make sure you have the correct splines on your adapter. You likely have a 21 spline inupt, so get a 21 spline adapter.
1uzRunner
63
Nov 10, 2018 03:58 PM
an1mal_69
Sep 8, 2015 09:40 AM
AkitaDog
Sep 3, 2015 09:01 PM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
