Limiting Strap Install Questions
Old Mar 22, 2004 | 11:04 AM
SkyRat's Avatar
Question Limiting Strap Install Questions
After doing some searching, I have found some good stuff on limiting straps. Has anyone seen a good write-up on this kind of install? I am wondering about welding tabs on the frame, and exactly where they should go? I know it is out there, I just haven't found it yet...
Old Mar 23, 2004 | 12:38 AM
ldivinag's Avatar
if your shocks are horizontal bolts, use them...
btw, how much lift and articulation do you have?
Old Mar 23, 2004 | 01:02 AM
superjoe83's Avatar
as long as you didnt put any longer than stock shocks on the front, you dont need straps, the shocks will only extend so far, but if you did put longer ones on then i would worry about your cv joints binding on full droop and would go for the straps
Old Mar 23, 2004 | 04:22 AM
TDiddy's Avatar
I agree that its very doubtful with a typical OME setup that you'll ever need limiting straps.
Old Mar 23, 2004 | 05:38 AM
SkyRat's Avatar
I was considering them for use with the OME 891 Rear Spring /N86 Shock Set-up.
It is only 2.5" of lift or so. My main concern is that the shock itself not be the limiter when it comes to droop.
mskalmus
May 28, 2017 07:51 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
