Lifting a high mileage 4Runner?
Old Nov 24, 2007 | 06:37 PM
PAULUNM's Avatar
I have had some people tell me that lifting (I'd like to do a 3inch) on a high mileage- 177k miles- truck will uncover lots of problems/vibrations from my existing suspension bushings and mounts... Any thoughts on this?
Old Nov 24, 2007 | 06:39 PM
ozziesironmanoffroad's Avatar
177k miles? your just breaking that bad boy in! its bs. when you get a lift they replace your suspension with the lift's suspension components. they must be thinking of FORD or DODGE.
Old Nov 24, 2007 | 06:52 PM
olharleyman's Avatar
Maybe if it's a FORD But you have a TOYOTA that kind of mileage is just warm up mileage. I did a 4" suspension with 190,000 and at 223,xxx only thing that shakes are the domestic trucks as I roll by.
Old Nov 24, 2007 | 07:15 PM
redvette's Avatar
I did a 3 incher at over 200k and It rides better than stock now.
Old Nov 24, 2007 | 07:28 PM
to4menon4u's Avatar
what about 300,000?
Old Nov 24, 2007 | 07:36 PM
pitpatt's Avatar
...wow /\/\/\ that is one sexy 2 door! i say go for it!!
Old Nov 25, 2007 | 10:35 AM
to4menon4u's Avatar
oh i have plans, just not the bank account for it (first is a new engine) i wanted to get about a 3-4" body lift then probably a 2 1/2 suspension and some bigger tires. thats all i need for the desert but im just speculating at the moment cuz im poor lol
Old Nov 25, 2007 | 05:01 PM
dirtoyboy's Avatar
maybe im dumb...but what the does mileage have to do with anything? its all about how the truck was maintained/treated....
mine has over 300 k .....the only vibes i notice are the swampers lol
Old Nov 25, 2007 | 07:23 PM
tc's Avatar
tc
Yes, but it is also the chance to fix them, so I would say it all evens out and go for it!
Old Nov 26, 2007 | 12:02 PM
bigarms23's Avatar
my runner has 200k miles and i just did a chevy axle swap this past summer and i dont have any vibration
Old Nov 26, 2007 | 03:09 PM
seaflea's Avatar
Ilifted my rig the first time with less than 100,000 miles on it. Then again after 250,000. I am still running the original 22-RE bottom end has never been touched.
Old Dec 2, 2007 | 03:15 PM
Diesel_Freak's Avatar
I did my OME lift at 240k... Now with the new engine, I figure it's pretty much a brand new truck. Unless you live in the rust belt, Toyotas will last as long as you let them...
Old Dec 2, 2007 | 06:57 PM
TrikeKid's Avatar
If you do it right, you'll be replacing all the bushings anyway, and unless your truck has been wrecked, the mounts should be just fine.
Old Dec 3, 2007 | 02:52 PM
elripster's Avatar
Ok, I think I know they they are talking about and it has nothing to do with brands gentlemen. There are components that might fail more quickly on a high mileage truck if you lift and wheel it. But, when you replace them the truck is good to go.
My 89 was stolen for the final time with 297,000 miles on it. It was a 3.0 5 speed, great truck.
I put a bracket lift on it because a) I didn't know any better and b) there really wasn't much else out at that time (10 years ago). The mileage with in the low 200,000's when I lifted it. That gave me driveline vibes. New u-joints didn't work. Custom axle shims didn't work. A $500 high angle driveline helped but there were still there just a bit. Regearing fixed it. It turns out there was just a little too much play in the pinion bearing, who would have thought? Since gearing lower increased the driveshaft RPM, it's not typically if fixes driveline vibes but that's how it worked out.
My power steering took a total dump. First the pump failed on a rock trail. Then, the pressure side powersteering hose burst in a parking lot. Then the steering gear started to leak badly. This was all about 3 months after lifting. I fixed it all an had 7 years of trouble free service from the steering and would still be driving it if it weren't for the thieves.
I'm not trying to discourage you from lifting and enjoying your truck, I'm just making you aware of the maintenance items we will all eventually face. If we lift and wheel the trucks, we just face them sooner.
Frank
Jun 1, 2021 01:51 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
