how much more lift to fit 285's?
Old May 19, 2004 | 07:54 AM
Digger33's Avatar
Chech the sig for what i have, i think overall i have about a 2" lift with the 265/75's. Also, the classic 2's have 3 5/8" backspacing. How much of a body lift would i need to fit 285/75's. I have already done the pinchweld mod.
Old May 19, 2004 | 08:49 AM
RTdawgs's Avatar
the question isnt how much more lift, but how willing are you to cut and grind.
you might not need more lift. but if you want to clear for sure, get a 2" body lift.
Old May 19, 2004 | 04:32 PM
waskillywabbit's Avatar
Talking 285s
I ran 285s with a 2" body lift and some pinch weld trimming with minor rubbing, but I certainly wouldn't wheel it like that...I now have OMEs all around for arround 4.5-5" of lift and no rubbing except on turning while stuffed.
Old May 29, 2004 | 04:25 PM
Digger33's Avatar
Bump! anyone else have any suggestions?
Old Jun 12, 2004 | 08:06 AM
Gringo's Avatar
I run 285's with a combo saw/ome lift--the only time I rub is going over a big bump--but I got a 1" RB lift I need to install along with some trim packers. I figure the lift will prevent any interference off-road. I took it on a run 60 kilometers down a running river and didn't experience any problems. All OME should be a fine set up.
Old Jun 13, 2004 | 07:34 AM
4Crawler's Avatar
Most folks run 1"-2" of body lift along with a mild suspension lift for 285s. With your more ofset wheels, you may find you need closer to the 2" lift vs. 1", wider up front makes fitting w/o rubbing harder. 1" works fine for stock wheels w/ 285s, 2" for wider wheels.
Old Jun 16, 2004 | 06:54 PM
data's Avatar
Senior Member
like others said, you're gonna need a full 2" of lift and you're gonna have to do some pounding! Have fun, it'll be worth all the pounding and grinding...
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Sep 4, 2015 09:27 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
