How do I protect my exposed air filter?
Old May 5, 2009 | 02:21 PM
Bigstack's Avatar
I just built a snorkel which i will create a thread for that but now my high performance air filter is on top of my truck. After testing it I thought.. How do I keep Mud off it and how do I keep Water from getting absorbed into it?? Any ideas or products??
Old May 5, 2009 | 03:37 PM
TOYOTA 1's Avatar
heres what Ive used before http://www.outerwearsracing.com/ they work pretty good
Old May 10, 2009 | 04:03 PM
awareness's Avatar
I've heard that a the foot part of a pair of panty-hose works well for shedding water and keeping mud and grit out in a pinch actually. Just keep in tight below the element with an elastic band or a hose clamp.
Old May 20, 2009 | 07:10 AM
Oktoberyzing's Avatar
i have one question about this type of setup. why would you put your air filter in open air straight to the intake. i deal with snorkeled 4 wheelers a lot, not much with trucks, but i know truck engines are more expensive than 4 wheeler engines. have you ever seen a snorkel like your talkin about break? if it does there is no type of filter between where you sayin your airfilter is and your engine. so if it breaks your suckin dirt.
like i said i've never fooled with trucks much, but i've seen ppl snorkel quads like this and i've seen em break and there goes the engine.
i geuss my question is, why wouldn't you use an airbox to snorkel it?
Old May 23, 2009 | 06:28 PM
yoterr's Avatar
from the looks of the truck looks like a 1st gen so the airbox thats on it is...well not really whater tight,anyways if i was in ur situation ide go with the outerware for now or even pantyhose and get a newer yota airbox of some sort and use that for the filter location and seal her up
Old May 31, 2009 | 01:03 PM
mud4life's Avatar
you can always reroute it into your glovebox, that way if your glovebox goes under, you probaly shouldnt have been there in the first place. Or ya just need bigger tires
Old May 31, 2009 | 01:20 PM
cutboggers's Avatar
in the cab = tooo loud
yes airbox to snorkel is the best setup.
factory carb aircleaner box works great actually.
Old May 31, 2009 | 01:30 PM
mud4life's Avatar
if its in the glovebox and you have the radio on and windows down how is that too loud?
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
accuracy
Aug 4, 2015 08:05 PM
Toyvana
Jul 29, 2015 10:47 PM
ryerye13
Jul 14, 2015 08:27 AM
