Hey guys, what lfit for 35s?
Whats up guys. This is my first post. I have a WHITE 93 Tacoma. Right now i have full skid plates,rocksliders,tube bumbers(front and back) exhaust/headers, I have ARB locker in the rear and tahst about it. What i want to know is how do i run 35s? We go to paragon 2-3 times a month, and do a lot of rockcrawlin and traisl. So what do you suggest? I was thinking a 4inch suspension and 3 inch body. I know that woudl fit them, but is 3nich body lift ok? I heard its unsafe,but so many people run it. SO what do you suggest? I am going to be running 529gears is i get 35s. Is that ok?
A 93 Tacoma? That is a new one on me.
4" suspension and 1" bodylift should do it.
3" bodylift with some aggressive trimming.
7" of lift is way too much for 35's, unless you are trying to be a big, bad yoter.
Originally Posted by 93TACO
nah its just a pickup, but i call it a tacoma. Its really a toyota pickup ext. So say i wanted to run 35s and ocasionally 38s. Woudlnt it be better to just run a 7 inch lift?
If you look around on this site a little bit by using the search function you will find a lot of discussion on these very topics.
Good Luck!~
1st I would go 7" suspention body lifts arent that great for the ammount of work you put in to them for what you get out of them. Ive got a 7" on my runner and it flexes like mad and no body. As for your steering use your ifs stuff and go get the high steer arms from allpro or marlin crawler.
I was going to write a smart ass ("you need 12"+) reply but in all honesty all you need is a 4" ProComp or Trail Master front and a set of Cheapie Chevy rear leafs.
You'll net 4" of lift and you'll be able to run 35's. I would 1" BL it as well.
The ball joint spacers will also make the thing actually work. The lift only jacks it up.
Here's a 92 Mini with this same set up on 285/75/16 on Aftershock at the Hammers.
What ever you do, don't install aftermarket t-bars. You'll really screw it up then.
Originally Posted by Flygtenstein
If you are a welder, then just do it.
If you need to ask questions like that, don't do it.
Brent says:
My thoughts exactly. Rip into it and then figure out what the hell you are going to do. Preperation is the kiss of death- do you think that Preperation H is just a fancy name- I think not.
Security! Who let this guy in here?
I think I mentioned the 4 plus 1 as well. Maybe even before.
Have you made any progress on this yet?
i dunno. Wel see what happens. Im tryng to get some more money in the bank. Thinking of keepin the truck asis, and just having a trailer truck. Somethin i can tow to the pit. Most guys around here have 44s and trailer them to the pit. www.njfourwheelers.com
I found a solid axle for $200. I think i'll pick it up and put it in next weekend. IM a qualified welder so it shouldnt be a problem. So now what do i need to do to the steering?
Just yank out all the IFS stuff and weld it right to the drop brackets in place of the old lower control arms and lower crossmember. Shouldn't take an hour or two....
scottyg486
Jul 19, 2015 05:34 PM
Iceman4193
Jul 15, 2015 04:48 PM
88yodabasket
Jul 13, 2015 01:32 PM
