Have I been offroading in 2wd all this time???
Old Aug 30, 2019 | 01:27 PM
frikinyankee's Avatar
Ok.. so this is pretty embarrassing. I've got myself a beautiful 86 22re 4runner, with 4x4 hi and lo, and front locking hubs...
So I didn't totally understand the function of the front locking hubs till i recently did some reading.. if i do NOT engage the hubs into the lock position.. and I engage the 4hi or 4lo.. then basically I'm moving my front shaft and CV axles.. but the wheels are NOT engaged to the axles? So in other words.. unless I have the locking hubs engaged to LOCK, then I am NOT driving in 4wheel drive? Is this true?
Not that I never had the hub lockers engaged, but I thought they engaged a front locking differential (i know.. i feel stupid) and not just engaged the wheels to the axles.. so I didn't always have them on when I had 4x4 on.. god I feel stupid...
Another question.. is engaging the 4x4 equivalent to locking the central differential? Or can the front and rear slip with respect to eachother?
I'm kinda new to all this, and totally loving the off roading.. don't be too hard on me
Old Aug 30, 2019 | 01:46 PM
millball's Avatar
The front and rear Cannot slip with relation to each other.
When in 4WD, either hi or low, the front and rear drivelines are direct coupled to each other.
Both the front hubs must be locked in order to get any front wheel drive. (Unless you have some sort of differential locker installed)
Old Sep 3, 2019 | 03:55 AM
arlindsay1992's Avatar
I had the exact same thought when I got my first 4x4 about the hubs engaging a front differential locker. Don't feel bad. I didn't figure it out until I was greasing the front driveshaft or something one day and realized it was able to just freewheel with the hubs free and the transfer case in 2 high.
There is no center differential. Engaging 4 (high or low) at the transfer case locks the front and rear driveshafts together at 1:1. No differential or slip between them. When in 2 high the front driveshaft is totally disconnected from the transfer case. No drive.
zachvu
Jan 25, 2012 08:40 PM
Sam1120
Apr 17, 2011 09:40 AM
1st_gen_runner
Dec 15, 2009 09:41 AM
95yoda
Mar 25, 2005 12:36 PM
alanbobalan
17
Nov 15, 2004 07:45 PM
