A great IFS idea...
Old Nov 22, 2003 | 12:51 PM
scott.475's Avatar
Thumbs up A great IFS idea...
Courtesy of Off-Road.com.
I think I will do this myself, imagine changing a front axle without having to take off the wheel!
CV Bolt Replacement
Old Nov 22, 2003 | 01:18 PM
Arnold's Avatar
I did it to my Toy and it definitely helps when it comes time to replace CV boots. It makes intalling the diff a lot easier too. I chose to grind the splines off the stock bolts after pressing 'em off though. The local nut/bolt place wanted over $50 for metric bolts. I thought that $ was better spent elsewhere.
Old Nov 24, 2003 | 05:02 AM
Victor's Avatar
Did it to mine also a while back. It does make swapping CV joints much easier. I still have to put a jack under the lower A-arm to get the angle straighter but other than that you are right - no tire removal and a lot less hassles.
Old Nov 26, 2003 | 02:37 AM
1WiCkEd_RuNNer's Avatar
I've replaced CV Boots a couple of times. And because of the lift, all I have had to do is remove the hub assembly. Because the weight of the truck keeps the front end somewhat level. I do to remove the lower part of the shock to make it a little easier. And the pressed in bots are still in!
88sasturbotoy
Jan 30, 2026 01:57 PM
Flying91
45
Apr 11, 2024 04:39 PM
XtraCab
Apr 12, 2020 05:25 AM
Gevo
Jul 29, 2015 11:15 AM
scottyg486
Jul 19, 2015 05:34 PM
