got my onboard air done
Old Jun 15, 2007 | 06:01 PM
INFINITY's Avatar
finial got all of the components for my set up.
-i got my neighbor to give me his air ride compressor. free so far
-i found the air tank at a illegal dump site when out hunting (those bastards). free but fabed up brackets and hit it with a coat of rustolium.
-all of the other stuff i got from home depot. about $15. ---50', 1/4" vinyl hose, fittings.
-switch, wire, connectors, zipties, and cut medflap squares (for in between the comp and fender well) i had lying around
let me know what you think, thanks
off/on switch
air comp, psi gauge, front hookup, and as soon as i get to town a one way anti bleed valve
air tank
rear hookup
Old Jun 15, 2007 | 06:12 PM
shantz's Avatar
looks great. how long does it take you to fill one tire?
I like the dual conections.
sweet
Old Jun 15, 2007 | 06:25 PM
bballchrism's Avatar
sweet is that a propane tank?
Old Jun 15, 2007 | 06:41 PM
Erich_870's Avatar
Looks good.
Don't go to any military bases though. A guard with one of those mirrors on a pole would likely get excited
Erich
Old Jun 15, 2007 | 07:16 PM
locked stock 84's Avatar
I would suggest putting some kind of cover on your couplers to keep the mud and sand out of em
Old Jun 15, 2007 | 07:19 PM
also, any thoughts of putting an adjustable regulator and a hands free chuck? just clip it and go
Old Jun 15, 2007 | 09:18 PM
INFINITY's Avatar
no, it is a littler "bubble" for air. but i guess one could work?
Old Jun 15, 2007 | 09:20 PM
INFINITY's Avatar
yea i am going to. before i go out. good suggestion
Old Jun 15, 2007 | 11:21 PM
Erich_870's Avatar
Do you know any of the specs on your compressor? You should test it's fill time to 80 or 90 psi.
I like your hose set up. I've never seen that connector system, but our first Home Depot won't open until the end of the month
Erich
Old Jun 16, 2007 | 07:48 AM
INFINITY's Avatar
under the wire cover it said it was like a 150 or so psi cut out. it took like 15 min to get to 100 psi yesterday. i figure if i have a flat the one thing that i do have is time or if i notice a tire is getting low i will just turn it on while driving down the road. i will time it later. i did not get the hose connectors from the depot they were laying around they work lust like the comp fittings but without the nut. the first section of the hose to the T is the poly line and the rest is the vinyl. the comp got so warm that with the more pliable vinyl heated up and with the 100 psi behind it ballooned out and popped. the poly line disperses the heat and does not expand. the hose set up was very simple to install and no problems yet.
Old Jun 17, 2007 | 10:50 AM
INFINITY's Avatar
ok so i tested it today and it was a little bit slower than i thought for it to build up to 110 psi it was 23 min just on the batt. with the engine off. not the nascar of the air compressor world but i am happy with it i would be even happier if i dont have to use if you know what i mean.
sanctfy
Sep 13, 2015 06:33 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
old87yota
Sep 9, 2015 12:39 PM
EatChipsNow
Sep 9, 2015 01:25 AM
some drunk guy
Sep 4, 2015 11:55 PM
