Gear Ratio and Tacoma E-Locker - Can I use one from a Tacoma?
Old Oct 30, 2003 | 07:55 AM
jataga's Avatar
Question Gear Ratio and Tacoma E-Locker - Can I use one from a Tacoma?
I spoke to a person at Toyota and gave him my VIN number so I could find out what my gear ratio is and he was no help. He had mentioned an Axle Code or specs on the inside of my door but I didn't see anything there.
Here are my questions:
• How do i find out what my gear ratio is on my 4Runner?
• Will an E-Locker from a Tacoma (same generation 96-2002) fit on my 4Runner?
• If I am not re-gearing, does it make a difference with the parts that come with the E-Locker?
Thanks,
John
Old Oct 30, 2003 | 10:37 AM
crawler#976's Avatar
The non E-locked Taco's and Third Gen Runners used a different housing and 8.4" ring/pinion than those equiped w/ the E-Locker. The E-locker is based on the "old" 8" ring/pinion and housing, so you'd have to swap out the whole axle. ARB makes a locker for the Taco housing- it would be cheaper to put it in than buying an entire axle.
Old Oct 30, 2003 | 11:58 AM
Flygtenstein's Avatar
All 3rd Gen runners have V-6 8" rear axles, e-locker or not.
Non-TRd Taco's with open diffs get the 8.4" along with some T-100's, the Tundra and the Sequoia.
With housing mods that can be found with the green button, you can put an e-locker from a Taco in your rear end.
You should have a door jamb code that is referencable to charts in the search. Tentatively, V-6 autos with 16" wheels will have 4.30's while the sticks will have 4.10's.
Old Oct 30, 2003 | 12:36 PM
thanks for the clarification! I was under the impression the 8.4's were not usable!
Old Oct 30, 2003 | 05:17 PM
Shane's Avatar
If the axle code is not listed on the doorjamb, then it should be on the placard on your firewall.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
