fj lift question
Old May 6, 2009 | 09:18 PM
xred5x's Avatar
fj lift question
I'm sure I'm not the first to ask this question but....I want to put a lift in my 2007 FJ Cruiser.
I want to be able to fit a 33" or a 285/70/17.
If I have a lift installed by someone "OTHER" than the Toyota Dealership will I have warranty problems?
Has anyone experienced any warranty problems as a result of a leveling kit or a 3" lift?
Is there a particular make that is recommended?
Am I covered if I at least get the lift through the part dept at Toyota, obviously I would rather install the lift myself as Toyota wants an arm and a leg to install anything and I can't get a straight answer from them regarding warranty other than if they install it my warranty is fine.
Any advice?
Old May 7, 2009 | 06:02 AM
racedirt1's Avatar
You may want to look at www.fjcruiserforums.com
Old May 7, 2009 | 11:12 AM
VSU_4runnin's Avatar
im pretty sure any modification to the suspension voids warranties, but thats just what ive heard around... Corey could you help shead some light on this?
Old May 7, 2009 | 11:32 AM
Corey's Avatar
Co-Founder/Administrator
Aftermarket lifts are generally covered 100%, I know mine is.
Toyota may also install it for you, you might check with them.
They sell FJs equipped just like mine with 33" Pro Comp tires, Old Man Emu 3" lifts, ARB bumpers, and Warn winches.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
4Runnin2000
Jul 29, 2015 06:09 PM
coffey50
Jul 28, 2015 10:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
