Fabtech lift for 2WD Prerunner
Old Nov 3, 2004 | 07:13 PM
Pretacopower's Avatar
Once I get rid of the hopeless piece of junk '85 sitting in my garage, I'm entertaining the idea of building up my Prerunner, and I had a question for you guys.....
I'm looking into the Fabtech 0-3.5" lift kit for the Tacoma Prerunners as seen here in this link...(I'm looking at the Performance kit)
http://www.truckaddons.com/Catalog/s...yota_2wd_1.htm
Anyway, my question regards my understanding of this kit. This would allow me to lift the front end of the truck anywhere from 0-3.5" correct? Giving it a "real" Prerunner stance?
If anyone can verify that for me I'd appreciate it...I can't seem to find any more details on it.
Oh, and don't recommend a long travel kit instead....I'm not that rich.
Old Nov 3, 2004 | 09:02 PM
Albuquerque Jim's Avatar
I have these coil overs on my truck. I like them for rock crawling because they are very soft. Even with the swap bar connected I can compress them to the bumpstops and they will droop as far as possible.
With that said I would not try them on a pre-runner unless it is only to look at. If you try to hit any jumps at high speed you will bottom out and probably start tearing stuff up. You need SAWS or something stiffer for a prerunner.
Old Nov 3, 2004 | 09:09 PM
Yeah, I won't be doing any high speed jumps or anything, as far as I know thats what the long travel kits are for and those run around 3 grand
I'm basically looking for a good performance lift, one that'll be able to take a good beating but nothing like getting air off of jumps.
If anyone has any other recommendations, I'm all ears
Old Nov 3, 2004 | 09:34 PM
turboale's Avatar
Well,
I will say this... I know you were not looking at the regular one, but i'm just going to give you more reason not to look at it. It took me 5 days to replace my shocks in a setup like that. Mine is a downey coilover and they use bilstein shocks, but thats besides the point. The threaded collar rusted to the shock and I had to cut the old shock in half and grind out the screws from the back side, then use a 20ton press to push the shock out. Now i'm doing the same thing to get the damn things back on (they should be ready to go on tomorrow. If you aren't going to wheel the thing, there is no use in spending all that money though. Just get a spacer lift and be done with it. You should upgrade your shocks for a better ride but I think that is overkill for a truck thats going to be rarely taken off road. These lifts you have shown will not widen your stance (like a prerunner) for that you need a long travel kit... it will just raise the stance and allow for bigger tires. If you combine a spacer lift and wheels with less backspacing or if you get wheel spacers that will give you the wider stance your looking for.
Good luck!
Old Nov 3, 2004 | 09:42 PM
Originally Posted by turboale
Well,
Good luck!
Thanks for the info!
I thought about just going with a general lift, but I do like to go on a good off-roading trip every now and then and was hoping to find something that would make it a little better performance-wise. I know that usually when people want to do this with 2wd trucks, they go with long travel kits....but those things ain't cheap
I'll prolly search a little and see what else is out there....thanks for the advice!
Old Nov 3, 2004 | 11:26 PM
jimbo74's Avatar
i did spindles on m ytruck... they are awesome.. a lot stronger than stock.... and i beat the crap out of my 4x2.... fabtech is a great company to deal with....
Old Nov 4, 2004 | 07:52 AM
They don't make spindles for 6 lug Taco's, only the 5 lug
Old Nov 4, 2004 | 02:07 PM
pinnacle's Avatar
Why not get a Sway-a-Away coilover.
Clicky
Pedalpwr27
Aug 13, 2015 06:37 AM
landrunner
Aug 5, 2015 09:18 PM
coffey50
Jul 28, 2015 10:55 AM
colasurdo
Jul 16, 2015 11:32 AM
