Eaton G80 MLocker for Toyotas?
Old Jul 19, 2017 | 11:15 AM
Fr1tzy's Avatar
Question Eaton G80 MLocker for Toyotas?
I talked to the Eaton tech and they said they don't have anything that acts like a G80 for any Toyota. My question is: Does anyone know of a differential like the MLocker (Complete locking when a wheel spin difference is sensed) that would fit in the 7.5" front diff?
Old Jul 19, 2017 | 11:38 AM
millball's Avatar
Don't think anything such is available. I don't think that even GM puts anything like G80 in front axles. Lockers in steering axles can be problematic.
One of the best alternative front carriers for street driven Toyotas is the Detroit Truetrac torsen type carrier.
It is not a true locker, it is a posi type carrier that uses a helical gear drive with no clutches to wear out. I have them in two of mine.
There are any number of true locking carriers and 'lunchbox' lockers for 7.5in, but their on pavement manners are not the best.
Old Jul 19, 2017 | 01:49 PM
Fr1tzy's Avatar
As of now I'm looking at the TrueTracks as my next best thing. The only problem is I want to have traction when I lift a tire. I am not too concerned about the steering because it will only be locked when wheeling. I do like the safety of having an open diff when driving in 4x4 on icy highways too so I can't go with auto locking diffs
Old Jul 19, 2017 | 02:31 PM
KZN185W's Avatar
I believe Harrop has an e-locker for the 7.5" Toyota front diff.
https://www.yotatech.com/forums/f2/y...unners-297879/
Old Jul 19, 2017 | 05:00 PM
Fr1tzy's Avatar
I'd love to go selectable, but I just don't have the money atm...
Old Nov 3, 2017 | 05:33 AM
arlindsay1992's Avatar
The G80 doesn't fully lock when wheelspin is detected. It is an open with a small difference in wheelspeed and a clutch type limited slip when a large difference in wheelspeed is detected.
Old Nov 3, 2017 | 06:54 AM
Fr1tzy's Avatar
For all intents and purposes it locks the axle. Yes, it uses clutches, but once engaged it behaves much more like a locked axle than a LSD.
Old Nov 3, 2017 | 08:25 AM
Not when you have a wheel in the air. I've wheeled with S10's/Sonomas and when they lift a wheel they lose drive. Even with throttle applied.
