Driveshaft Question (i think...)
Old May 3, 2006 | 08:12 AM
MikeKaduce's Avatar
I recently bought an 88 pickup and put the manual transmission in myself. When I go 45 miles per hour, the truck violently shakes up and down. I ruled out tires as the problem, since it goes down the road fine when I throw it in neutral. But when there's engine power to the wheels, it shakes awfully. Anyone know whats up or how i can fix it?
Mike
Old May 3, 2006 | 08:17 AM
SlightlyModified's Avatar
even with the truck in neutral it could be a driveshaft prob.
Old May 3, 2006 | 09:45 AM
BajaRunner's Avatar
Get a new driveshaft?
I've heard about guys getting them balanced, but, dont take my word for it.
Old May 3, 2006 | 11:51 AM
shiftless89's Avatar
check your motor mounts and tranny mounts as well as excess play in your u-joints
Old May 3, 2006 | 05:22 PM
BeaterToyota's Avatar
When the driveshaft was out of the truck, did the slip yoke get pulled apart? If the shaft got pulled apart, and then put back together with the u-joints on either end out of phase, then it could vibrate pretty bad.
I don't really know how to desribe it, but make sure that the u-joints on the t-case end and on the differential end are basically in the same position. If they aren't, pull the shaft apart at the slip yoke and rotate it until the u-joints are the same at each end.
4x4-runner
Apr 18, 2017 09:08 PM
mussy01
Dec 13, 2016 08:20 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
Sr5crawler
Jul 31, 2015 12:32 PM
