Downey off-road manual locker, for e-locker
Old Nov 15, 2008 | 06:21 PM
swapped89's Avatar
Exclamation Downey off-road manual locker, for e-locker
I was reading my new issue of 4wd Toyota Owner Magazine. And in the toyota holiday gift guide. It shows that downeyoff-road has a product to turn your 79-85 e-locker into a manual locker getting rid of all the electronics. seems to me that you could have an open diff or when the trail gets tuff jump out just like when you lock your hubs and lock your differential manualy! no air, no wires or electronics.
When an e-locker is engaged does it function just lock a full time detroit locker. it will allow one tire to go faster than the drive wheel around a corner but not slower so it pozzi's up?
I like the sound of this. what do you guys think. And i dont need to hear from the lazy poeple that say its a hassle to get in and out of your rig.
http://downeyoff-road.com/ChassisCom...s/Lockers.html
Old Nov 15, 2008 | 06:27 PM
littlecommando's Avatar
I saw that on there sight, and i like it, if i had elockes i would get that
Old Nov 15, 2008 | 06:43 PM
Hayes's Avatar
from what I have heard they are not as nice as they sound...
With an e-locker, if it malfunctions and cannot be turned on/off, you can still actuate it by hand.
I will have to see if I can find where I read this, since it is second hand information.
Old Nov 15, 2008 | 06:55 PM
BigBluePile's Avatar
Downey makes a cable actuated elocker conversion for the rear and I guess there's an issue with having to run cable to the front diff so they just made a pull tab to actuate it.
Old Nov 15, 2008 | 08:22 PM
swapped89's Avatar
im not talkin about the rear cable actuated ones just the front manual pull or push one.
Old Nov 15, 2008 | 08:38 PM
ok, well it's the same locker...just in the front...
it's full lock up, detroits are auto lockers.
Old Nov 15, 2008 | 10:02 PM
swapped89's Avatar
does full locked up mean its like a spool?
Old Nov 15, 2008 | 10:04 PM
swapped89's Avatar
ok so never mind the cable. does this thing work when hand operated and when its locked is it like a spool or an auto locker?
Old Nov 15, 2008 | 10:51 PM
86tuning's Avatar
Toyota e-lockers are spooled when they're activated, open when they're not. The lockers work great, but the actuator motors sometimes take a dump and can leave you stuck until you unbolt the motor and manually flip the fork to lock it up.
Detroit lockers and other auto-lockers click and clack and allow differentiation until you apply enough torque to it to lock it up.
Old Nov 16, 2008 | 12:53 AM
swapped89's Avatar
Does anybody actually have one of these installed on there rig?
Im either gonna get this manual locker for the e-locker or go with a lockright.
I want to know if anyone has installed this manual locker?
Old Nov 16, 2008 | 01:53 AM
4Runner202020's Avatar
well remember you gotta find one to fit your front diff... the only way of that is to get a land cruiser front axle, not just a regular toyota axle or dana. it has to be a land cruiser axle from years '91 to 97 i believe. its the 80 series.
bobby
Old Nov 16, 2008 | 06:18 AM
Hayes's Avatar
a standard e-locker will fit the front diff with some modification.
Old Nov 16, 2008 | 11:47 AM
swapped89's Avatar
sounds like a lil more hassle than im lookin forward to. ill probably just go with a lockrite or trutrac
Old Nov 17, 2008 | 10:30 PM
8T3's Avatar
8T3
I've used many lockers and as far as the front goes you want a selectable locker. ARB or Elocker. The only difference in the front is that you need to clearance 1 bolt head on the actuator to clear the leaf spring. No big deal. I run them front and rear and when they're on you're locked 100%, when they're off, it's just a regular diff. A front locker kills your turning radius and can be very annoying at times. Use it when you need it.
Here's a pic of the front. The bolt that needs to be clearanced is in the middle of the red box. I took about half of the head off.
Old Nov 17, 2008 | 10:35 PM
swapped89's Avatar
too expensive for my budget im gonna do 4:88s and lockrights front and rear
Old Nov 17, 2008 | 10:47 PM
4x4YOTA's Avatar
marlin sells thirds setup with elockers...I am actually looking into it for my rear cuz I dont want a full time locker in my 81 ...I have a detroit in the rear of my 83 and it feels like a spoil and I dont wheel enough to need a full time locker
Old Nov 17, 2008 | 10:59 PM
swapped89's Avatar
what kind of locker do you have
Old Nov 17, 2008 | 11:15 PM
4x4YOTA's Avatar
I have a detroit locker in my 83...
I am actually parting out the 83 and still have both thirds for sale they have 5.29 gears, rear has detroit and front is open $1000 for both
Old Nov 17, 2008 | 11:19 PM
swapped89's Avatar
4x4yota
are they 8'' diffs?
Old Nov 17, 2008 | 11:21 PM
4x4YOTA's Avatar
are they 8'' diffs?
yes they are! and they have less the 2000 miles on them and 2 trail uses
