Downey lift not high enough
Old Dec 6, 2005 | 11:39 AM
Boosted Chemist's Avatar
Resently this summer i bought and installed a downey economony lift kit, it was supose to come with 2" lift springs and i opted to switch them out for thier 3" units. After the truck settled i was around 37.5 inches from the floor to the bottom center of hte rear wheel wheel well. The front was set to around 37". Now after drving around for a bit, my rear sits at 36" and the truck has 1" negative scoot to it. I would love to bring it up to like 38" to make it look like a lifter truck.
Two options i have considered
lift blocks (accually bough them from autozone for 15 bucks), 4 new u bolts a nd 2 2" alum blocks with a hole for the leaf springs tit to si in
Shackles.
Now lifted trucks arent my speciaty, im more in to car, so what would u guys suggest to get my truck to sit 2" higher in the rear?
thanks
Old Dec 6, 2005 | 12:42 PM
4Crawler's Avatar
A few options.
Lift blocks will work but tend to increase the tendency for axle wrap.
Longer shackles will give lift, so 2" you'll need 3"-4" longer than stock shackles:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
Longer shackles will change the pinion angle if you have a u-joint (single-cardan) rear driveshaft, shims may be needed:
An add-a-leaf, especially a long thin leaf like the Ranch Soft-Ride AAL kit, will give lift and also help support the existing springs. Likely they have sagged because more wieght is being applied to them than they were really designed for. Downey springs are notorious for this.
Best option is AAL then make up the rest of the lift with a shackle.
Old Dec 6, 2005 | 12:57 PM
Snorkeldepth's Avatar
I need to fix the sagging rear on my truck. I thought seriously about going with Downey springs. But, then I started to read about problems like this. I read about AALs and shackles. Assuming that Alcan springs are in the budget is there any reason why you'd want to go with AALs or shackles instead?
I realize that Chemist probably doesn't want to trash his new springs.
Old Dec 6, 2005 | 01:40 PM
4Crawler's Avatar
A new, custom built spring pack would be the best answer. For Alcan's, get the rear axle of the truck weighed and call them up with the lift and load requirements to get the best working springs built.
Old Dec 6, 2005 | 01:59 PM
By "rear axle weighed" do you mean driving the rear axle onto a truck scale? I sure hope so!
Old Dec 6, 2005 | 02:10 PM
4Crawler's Avatar
Correct, you need to measure the weight on the rear axle in order to be able to tell the spring builder how much stiffness to build into the spring pack. Getting the whole vehicle weight will not tell you the front/rear split.
Old Dec 9, 2005 | 08:07 AM
colsoncj's Avatar
I've rebuilt a few downey packs from abuse and sagging... did you use the lowest two leafs from your original pack on the downey pack (overload and bottom leaf)? I was never informed of that with my several packs, and it sounds like it may help. I eventually just went chevy 63's, and getting ready to add some blocks on top of that.
Old Dec 16, 2005 | 09:51 AM
i just used the helper spring or that bottom most leaf like the instructions said.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
