Developing new compressor
Old Aug 19, 2009 | 02:43 PM
Wheelingnoob's Avatar
How about CFM on both pumps?
Old Aug 19, 2009 | 02:49 PM
Plumbrbob's Avatar
the duty cycle is 100% very nice
the CFM rating is very important tells us what kind of air tools we can expect to run.
oh yea price?
Old Aug 19, 2009 | 03:07 PM
tc's Avatar
tc
Great, another Superflow/Viair/whatever clone.
From the specs above, the 1500 does 0.9 CFM, the 2000 does 0.8 CFM, so you ain't gonna be using air tools off them.
The fill times for the tanks sound impressive until you figure out how much air is actually contained in your tires:
http://www.4crawler.com/4x4/CheapTri...tml#HowMuchAir
I don't want to sound like I'm knocking the product - I just had hoped that for once somebody would listen to all the people requesting CFM for a more reasonable price than OASIS. There really are compressor designs better suited to our needs than the standby reciprocating.
Old Aug 20, 2009 | 07:51 AM
SunPerformance's Avatar
CFM is listed here:
http://sunperformance.com/?page_id=111
Old Aug 20, 2009 | 09:42 AM
  #25
First, The MSRP on the ARB CKMA12 on most websites is at $265 to $274 such as these websites
http://www.expeditionexchange.com/ca...378&bestseller
http://www.man-a-fre.com/parts_acces...Compressor.htm
and here is another thing. If you want to go with ARB's 33% Duty Cycle to only stop working on you when over heated, go ahead and wait your 30 to 40 minutes to wait for it to cool down to restart.
But If you want to pay a few extra bucks for a 100% Duty Cycle Air Compressor that will never have to make you wait, our compressor is the one to get.
We have given our Compressor to a few well respected Off-Road enthusiest such as Larry Bernstein, the owner of Dirty Parts and here is what he had to say:
"Sun Performance, manufacturer of the QuickAIR line of compressors, was one of the pioneering companies in protable air systems for off road use. Starting with their QuickAIR 1, 2, and 3 models, they established themselves as innovators with small, efficient air compressors for portable use on the trail. But, it's a tough market in the US, and while the company went through some changes, other companies picked up the slack, offering competitive systems and newer technology than the Sun Performance had on tap.
That has now changed. With new management, and a new drive to produce top notch products for a demanding audience of hardcore off-road enthusiasts, Sun Performance has released its new line of portable and permanent mount air compressors: The QuickAIR X series. Consisting of two levels of power, each available in a permanent and portable configuration, Sun Performance is looking to become the #1 source for off roaders.
Ivan Wong, national sales manger for Sun Performance, approached my about trying out the new QuickAIR X units. As a dedicated CO2 tank user myself, I was interested to see just how capable and reliable the new compressors are. Ivan agreed to provide a new unit for me to try out, and I took it with me to the Outdoor Adventure SummerFest 2009 event in Big Bear, CA this last weekend, using it as an air station for all who wanted to use it.
The model Ivan gave me is the QuickAIR X 2000 SE portable, the current top of the line model. Like it's smaller sibling, the 1500 SE, it is a 100% duty cycle compressor, runs on 12V DC (attaches to battery directly with clamps - too powerful for the power outlet on the dash), and comes as a complete kit:
Compressor, 25' coiled with intergrated pressure gauge and screw on valve connector, carrying hande, battery clamp power connectors, and integrated on/off switch on the compressor body. The 2000 SE has a max working pressure of 200 PSI, while the smaller 1500 SE is limited to 150 PSI max (plenty for tires).
The 2000 SE weighs about 9 1/4 lbs, and is rated to fill a 5 gallon tank to 200 PSI in just over 11 minutes.
I used the QuickAIR 2000 SE during the week prior to the event around the shop; customer's tires, my own tires, an had no issues - in fact, it seemed to be the fastest portable compressor in it's size I've used - but I could compare it better in real world use in Big Bear, and see if it's 100% duty cycle rating was for real.
Well, we used it all weekend, and never did the motor strain to keep up. It's relatively quiet, and given it's 100% duty cycle and high max pressure, it made easy work of filling many, many tires of the 2 days of wheeling. At the end of Sunday's ride, getting ready to go home , we put it up against an ARB hi-output compressor, and it filled tires in HALF the time (285/75R16 from 15 PSI to 35 PSI; ARB- 6 min 11 sec, QuickAIR 2000SE 3 min 4 sec). Ths was cinsistant for all the tires we filled; it never strained, it never stopped, and it was always faster than the ARB we had available. Now, we also used the CO2 tanks to give a run, and while it is a fine unit, with excellent construction (nice military green heat sink looks good, too), it was no match for the tanks. But, tank capacity is finite, and it may be worth saving for use with air tools on more serious excursions, while using the QuickAIR for the tires. The only real grip I had is with th e pressure gauge; it worked fine, but is scaled for 200 PSI, and is not useful for precise readings at lower pressures. Not a big deal, but I would like to see a low pressure gauge option or addition for use on the trail.
Overall, I found the QuickAIR X 2000 SE to be well built, well designed, user friendly, and works as advertised. While I don't plan on removing my CO2 system, it makes an excellent alternative to anyone looking for a portable compressor that can be run all day, has a very high max pressure (and a 300 PSI model is on the way as we "speak"...), and packs away in a nicely set up bag for storage. Permanent mount models of both styles are also available at lower cost - they come a la carte, and do not have the integrated on/off switch on the body."
Old Aug 26, 2009 | 11:21 PM
  #26
Matt16's Avatar
>>4cfm, 100% duty cycle, >$100
Belt driven compressors kick butt. I can run an air drill without a air tank. Fills tires from trail pressure to road pressure in under 30 seconds.
justdifferentials
14
Jun 11, 2017 08:36 PM
coryc85
Dec 5, 2015 08:42 AM
Firefightersink15
Nov 23, 2015 10:32 PM
JUICE222
Oct 13, 2015 08:50 AM
Badlander
Oct 10, 2015 08:05 PM
