dana 44 on an 86?
Old Feb 11, 2004 | 08:16 AM
jsrusse11's Avatar
dana 44 on an 86?
i'm buying an 86 yota and might have found a good axle for a swap. the ad says:
Originally out of a 67-69 waggoneer. 4.10 open
Closed knuckle housing. Chevy disks. 5x5.5 pattern, complete, everything works. International hubs. approx. 62" wide. SOA pads 35" apart
may need brake job.
he only wants 100 bucks. since its so cheap does that mean theres probably something more wrong with it. is this a good deal and if so will it work on my truck. or will i have to do a lot of work to make it fit?
Old Feb 11, 2004 | 08:17 AM
jsrusse11's Avatar
dana 44 4 my 86
may need brake job.
Old Feb 11, 2004 | 08:21 AM
toy283's Avatar
No, it will not work on your truck. Wagoneers have a driver's side differential, Toyota trucks had a passenger side differential until '95 and the Tacomas.
Old Feb 11, 2004 | 08:42 AM
justinh's Avatar
actually a waggy that old should be a passenger side drop, they didn't use driver side drop until the early 80's
Old Feb 11, 2004 | 12:40 PM
Napoleon047's Avatar
dont get it
D44's are cheap and plentiful that one has a lot of stuff that would need changing anyway:
you want open knuckles
you want a 6x5.5 bolt pattern (to match your rear axle)
35" spring pads?? talk about outboarding your springs, stock toy are 29" apart, people complain when they have to use 31.5" spring pad width on a waggy D44
ideally, you want a GM D44 with flat top knuckles and then have the long side cut down.
Old Feb 11, 2004 | 12:43 PM
79 and down - passenger side diff
80 and up - driver side diff
Old Feb 11, 2004 | 04:42 PM
jsrusse11's Avatar
i'll pass on this one then. so what should i look for in an axle then. what gm's are good to get them off of and what all works. or should i just go for a toyota solid axle. is a dana 44 too much trouble?
Old Feb 16, 2004 | 06:51 AM
INsr5runner's Avatar
why not stick with a toy 8" for the front?
Old Feb 16, 2004 | 07:34 AM
44Runner's Avatar
They were only driver's side from 1980 on.
I would look for a 74-79 Wagoneer front. That would be a better starting point...
Old Feb 16, 2004 | 07:35 AM
44Runner's Avatar
weak housing
width
birfields
Old Mar 10, 2004 | 08:52 PM
lcopelan22's Avatar
I'm not saying anything bad about a 44 at all. They're great axles. You asked if it would be too much trouble, going with a Yota axle would be cheaper for sure. Me and my buddy have been building his Wrangler that we swapped a Waggy axle into. A couple of days ago we threw the new Chromoly Shafts into it. Those shafts cost $580.00. You can Birf, and Chromoly Front and Rear in a Yota for right at that price.
Old Mar 11, 2004 | 02:06 AM
44Runner's Avatar
Yes, it is cheaper to build a toy axle, but they aren't as strong. That is the trade off...
Old Mar 11, 2004 | 09:10 AM
also, keep in mind that 4.88 is the lowest D44 ratio that matches a toy ratio. some ppl will use a 5.38 with a 5.29 (1.67%) difference. on hard rock surfaces, the driveline will have a lot of binding and one guy i know hates it personally, so hes going to a D60 rear to match the ratios exactly. if all you see is loose dirt, mud, or loose rock trails, the mismatched ratios will be unnoticed.
Old Dec 8, 2004 | 03:43 PM
ravencr's Avatar
I've found a 85 Waggy axle for $50-100(not sure yet), but I'm wondering if it will fit on my 1997 4runner and be a good choice for a SAS?
Chris
Old Dec 10, 2004 | 08:34 AM
justinh's Avatar
Chris
as long as it doens't have the vacuum disconnect on the diffrential then it is what you need, if it has the vacuum disconnect it isn't, 86 shouldn't but if it does it will be on the differential and easy to see.
PNWrider
Oct 30, 2015 08:14 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Cebby
Feb 20, 2007 11:33 PM
1WiCkEd_RuNNer
Mar 21, 2004 03:43 PM
