cruiser coils and panhard
Old Oct 14, 2004 | 08:31 PM
Mad Chemist's Avatar
I'm not sure I understand the engineering either, but it seems like there shouldn't be a difference between a bent rod and a straight rod. The distance between the pivot points on the axle and on the panhard bracket should be exactly the same in either case, if the axle is centered under the vehicle. If you compared the length of a straight bar and the length between the two heims on a bent bar (in a straight line, ignoring the s-curve, they should be the same). As far as drop bracket versus a lengthened bar (S or straight), there is a difference due to the upper pivot point being lowered by three inches relative to the stock location. Does this make sense or is am I talking out my ass? I've yet to anything after the lift, but am thinking about a longer rod at the moment (huh, huh huh huh, huh, I said "rod").
Old Oct 15, 2004 | 05:06 AM
Flygtenstein's Avatar
The geometry is pretty straightforward about hypotenuse extension, but there seems to be more than that. There is roll axis and another thing that escapes me that also influence how the truck wheels and does or does not rub.
I would drop it to get it in the ball park and then see what added length would do.
Old Oct 15, 2004 | 07:06 AM
Robinhood150's Avatar
Yup, you're right. As far as how the suspension moves a straight or bent panhard doesn't make a difference as long as they're the same length. The only reason you would need to put a bend in it is if you need clearance or you want the rod ends in a certain orientation. A bent rod will also flex more.
Old Oct 15, 2004 | 08:10 AM
RobG's Avatar
Originally Posted by Flygtenstein
If you are serious about uppers, I still have the one that was not used because of the bent one that has one heim. It is adjustable from stock to 1.5" over.
Not sure what you have ?
- A Rubicon SuperFlex Joint ?
- An OEM Uper Arm ?
- An AP Upper Arm ?
- A custom upper arm ?
I'm a little slow.
Old Oct 15, 2004 | 08:36 AM
  #25
Cebby's Avatar
I think he has Spidertrax arms.
Old Oct 16, 2004 | 01:00 PM
  #26
914runner's Avatar
- An OEM Uper Arm ?
- An AP Upper Arm ?
I'm a little slow.
I belive he has custom upper arms with hiems at both ends, and custom lower arms with a RE joint at one end and a hiem on the other end?
Old Oct 20, 2004 | 08:37 AM
  #27
Yeah, I have Spidertrax arms. I have been without reliable computer for a while.
I have an upper arm with one heim in and a bung for another heim that would be perfect for this operation. I did not use it because I needed a bent arm on one side.
Old Oct 21, 2004 | 12:20 PM
  #28
RobG's Avatar
I don’t understand 'a bung for another heim'. Does that mean it is not a complete arm? Would I just need to buy a std. heim to make it operational?
I think I’m interested (pending above questions), but I am extremely tied up at work for the next 2 weeks and busy making necessary mods for a trip in 3 weeks. May be a little slow in response. What do you want for it?
Thanks all for the Interim responses
Old Oct 21, 2004 | 02:00 PM
  #29
It lacks one heim to make it complete. We had to rob the heim to go in the bent arm.
The arm I was offering, looking left to right, goes as follows:
Heim, bung, tube, bung, nothing.
If you want/need it, I will dig it up and check to see if the one is right or left hand thread and advise you accordingly.
Old Oct 21, 2004 | 03:25 PM
  #30
RobG's Avatar
I get it, I am more than a little slow these days.
No Need to check the thread pitch. What ($$) do you want for it ?
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
TheBFA
Feb 15, 2020 06:55 AM
the_supernerd
Oct 1, 2015 09:20 PM
4runnerFireman
Sep 29, 2015 06:24 AM
justdifferentials
Sep 5, 2015 06:52 PM
