Crossover steering ?
Old Sep 25, 2008 | 10:25 PM
SpecialScottie's Avatar
How many inches of lift is required to use crossover steering.
I plan on using the allpro crossover kit on my 85
Old Sep 25, 2008 | 10:34 PM
fillsrunner4's Avatar
Should be atleat 3"
Give them a call. Dont buy from any company without calling! (it guarantees better service and the right parts)
I know from much experience!
Your gonna have to use and IFS steering box too you know? Hysteer is very nice and much stronger. Marlin and tail-gear also sell the kits along with a Few other too!
Allpro used to issues with the links being to close and interference between the drag link and ti-rod. I still have there kit and havent had much issue aside from drag link and ti-rod clearance but I would call them on it and ask if they have fixed it yet. If they dont know what your talking about I would try another place. They should know about it though and Im sure they do!
Old Sep 26, 2008 | 11:47 PM
Great info
Thanks fill!
Old Sep 27, 2008 | 06:21 AM
4Crawler's Avatar
Yes, 3" is about as low as you can go w/ crossover steering to allow room for the tie rod, drag link and pitman arm to fit between the spring and frame. I ran about that much lift on my '85 w/ AllPro x-over steering. Had to iterate a few times to get enough height on the passenger side arm to let the drag link clear the springs at full droop w/o hitting the frame at full compression. My draglink did rub on the passenger side springs enough to scrape the paint off of it and on the driver's side, the pitman arm would rub on the springs at full compression, you can see the scrapes in the spring paint in the image below:
[img]http://www.4crawler.com/4x4/CheapTricks/CrossoverSteering
/DrvSide.jpg[/img]
And what I did to remedy the slight interference:
http://www.4crawler.com/4x4/CheapTri...ringHangerDrop
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
