Cheap on-board air question?
Old Apr 23, 2008 | 03:37 PM
85TurboRunner's Avatar
I bought this little compressor from harbor freight the other day, it has the same specs as the warn model but its cheaper. What I was wondering is if its ok to have it mounted horizontally. Is there any type of oiling system on these things that could be affected by mounting it on its side?
Old Apr 23, 2008 | 04:05 PM
Erich_870's Avatar
From what I remember, the cheap ones are oil-less so it shouldn't matter which way you mount it.
How much did that run you at Harbor Fright?
Erich
Old Apr 23, 2008 | 09:21 PM
n16ht5's Avatar
i had my same one mounted like that for years...
$50 on sale at harbor freight
Old Apr 23, 2008 | 09:33 PM
abj27's Avatar
you had it for years? Does that mean it worked for years? How did you like it?
Old Apr 24, 2008 | 06:53 AM
dirtoyboy's Avatar
Whats the CFM on that bad boy?
Old Apr 24, 2008 | 07:03 AM
seafarinman's Avatar
I have one of the MV50 compressors hard mounted under the hood of my truck with a Viair 110/150 pressure switch and a 2.5 gal air tank. It works okay, but there was a lot of condensation in the lines so I installed a water separator in the line before the air tank. I recently picked up one of these : http://www.amazon.com/Q-Industries-Q...d_i=B000BM8RT8
and I will be swapping out the MV50 for it once the 2RZ swap is done on my truck since I will have more room under the hood for accessories once the 3.0 is gone.
Old Apr 24, 2008 | 11:20 AM
heres the specs:12 volt motor, 30 amp, 150 PSI max., Air delivery: 1.35 CFM @ 40 PSI, 1.14 CFM @ 70 PSI, 1.05 CFM @ 90 PSI, Overall dimensions: 11-1/4'' L x 5-1/2'' W x 7-1/2'' H, Overall weight: 11 lbs.
The site says its $64 but when I went to the local store it was $50 so I was pretty happy about that. I also picked up a 5 gallon tank for $20 and now that I've seen that pressure switch seafarinman mentioned I might be getting one of those too. Time to go bolt this thing in.
Old Oct 24, 2008 | 06:50 PM
So I finally got all the pieces to get my OBA up and running using that harbor freight compressor.
I hooked it up to my 5 gal. tank and started filling it up and when it got to 100psi the compressor broke .
It still runs but does not build any pressure. Maybe its just an O-ring or something.
Anyway if I can't fix it I'm gonna look into one of the Q industries MV-50.
What a bummer.
Old Nov 4, 2008 | 03:59 PM
premirrider's Avatar
Another option is to use a compressor out of a car that has air ride. Check the local junk yards for one. I know that lincolins have them. Just an idea.
Old Nov 20, 2008 | 09:52 AM
machine23's Avatar
yea, the lincolns do have them. but you have to be real careful when you go to drill out the air outlet for the air chuck quick disconnect. i screwed up mine real quick. i would recommend using a drill press. and make sure its extremely stable. it should be in an early 80's car. its under the hood. on the drivers side. actually both sides but the drivers side is easiest to pull out.
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
terminator
Jul 27, 2015 07:13 PM
sojourner567
Jul 16, 2015 08:52 PM
Avenged
Jul 9, 2015 07:55 AM
