Blazeland on t100. Best steering upgrades? And shock lengths
Old Mar 8, 2011 | 11:19 PM
Zpd426's Avatar
I'm about to purchase a blazeland long travel kit and was hoping I could get some feed back on what sort of steering upgrades I should do? I'm not really going to be doing any jumping. Also the kit recommends A certain bilstein shock (#f4-be5-6582-h5) that mounts up to the stock location. Does anyone know if the same length shock is right for the t100?
Old Mar 9, 2011 | 12:13 AM
vital22re's Avatar
totally a bro
so question for you... what axles are you going to use? You realize the bzlnd kit is built to use the t100 axles and is made for the trucks and runners. Do they have extra long t-100 axles for the use on the t 100? Try google searching the part number for the bilstiens. You should be able to find out what applications they are for, namely if its the stock length or if its for lifted rigs.
Old Mar 9, 2011 | 06:21 AM
YotaWoRx's Avatar
correct. unless longer custom made axles are used on a T100, 4wd will not be able to be used...
Old Mar 9, 2011 | 06:49 AM
250000_yota's Avatar
I would recommend talking to Total Chaos about the axle issue. They say custom 300M axles are used when installing their kit's on T100's. As far as the steering is concerned, your definitely going to want to upgrade your idler arm, either with a brace, or, again, with Total Chaos. Here's a link to their idler arm. It's the third item from the top.
http://www.chaosfab.com/toyaccess_4wd.html
Old Mar 9, 2011 | 10:08 AM
Zpd426's Avatar
I'm aware of the axle issue. The total chaos axles are pretty sweet but I can sleeve or send my stock ones out to be modified for less money. And since I'm only running the v6 I really don't need the 300m hardened stuff. The halfshaft is the week point in my driveline anyway. Ill definently check out that idler arm though. And I'm thinking since the suspension is identical for the t100 and the older trucks the shock should be the same length and mounted the same... maybe? Time for some google searches!
Old Mar 9, 2011 | 11:35 AM
Zpd426's Avatar
I just called offroad warehouse it looks like other than the valving the t100 and 85-95 toys use identical length shocks. As for the steering. I noticed tc has a full steering kit with rods and other stuff. Is this something I need or can use the stock setup with just the pitman arm? Oh also steering stabilizers?
Old Mar 9, 2011 | 12:25 PM
LGcrawler's Avatar
thats goin to be sweet, post pics when it happens
Old Mar 9, 2011 | 03:36 PM
thrice's Avatar
Definitely want to see this!
Old Mar 10, 2011 | 12:11 AM
Robert m's Avatar
if you not going to be jumping your truck why not just do a lift kit?
Old Mar 10, 2011 | 12:46 AM
Zpd426's Avatar
Because a lift doesn't increase suspension performance and the longtravel will be sweet for both high speed and crawling arrticulation while keeping my center of gravity low. I do 70% desert 30% crawling. If I get into some more hairy stuff I might get a lift later.
Old Mar 10, 2011 | 10:24 AM
Robert m's Avatar
yeah i know what LT suspension does (see sig) i was just curious what your plans were with the truck cause it didnt sound like you would need that kind of setup from your first post. good luck with the blazeland kit...
Old Mar 10, 2011 | 11:20 AM
Zpd426's Avatar
Haha nice ride! Sorry I'm usually on the mobile version of the site on my phone and that stuff doesn't pop up.
Old Mar 17, 2011 | 09:19 AM
klsmith925's Avatar
try to get uniballs to ball joints are useless
Old Apr 9, 2011 | 06:38 PM
LGcrawler's Avatar
any updates?
Old Apr 9, 2011 | 06:57 PM
Zpd426's Avatar
Ya I just got my shocks in. I went with 8.5 fox remote res. Gonna get the blazeland shock hoop. As for the axles I can use the total chaos extended ones. As for steering I'm going to upgrade as stuff wears out. Balljoints first. Balljoints are weaker for big hits but last much longer.
Old Apr 9, 2011 | 06:59 PM
Zpd426's Avatar
It will be a couple months until I get everything together. But ill for sure post pics
Old Apr 9, 2011 | 09:37 PM
LGcrawler's Avatar
ya man lookin forward to the pics
Old Jun 16, 2011 | 10:13 AM
T100cowboy's Avatar
SSSOOOO????? Any updates yet?! I'm looking at getting this kit ASAP for my T. would like to see how good it works out what all is used/needed for a mild LT kit.
Old Jun 16, 2011 | 11:57 PM
Zpd426's Avatar
Just need the kit axles glass and shocks plus new ball joints if yours are worn.. I broke my femur on my bike so the project is on hold.
Old Jun 17, 2011 | 12:00 AM
Zpd426's Avatar
Oh and shock hoops
