BJ spacers in! Waiting for AALs and Alignment
Old Apr 29, 2007 | 03:20 PM
chrishf12's Avatar
I installed my bj spacers thursday night and gained around 2.75" total lift in the front. My 3" Tuff Country aals should be here wednesday. In the mean time the underside is getting a fresh coat of black paint. Anyone have any tips on installing the AALs?
Old Apr 29, 2007 | 04:21 PM
4Crawler's Avatar
Start hitting the u-bolts with some good penetrating oil.
Old Apr 29, 2007 | 05:47 PM
chrishf12's Avatar
10-4 on that! I already have to replace one of the torsion bar bolts and dont need to replace any of the U bolts.
Old Apr 30, 2007 | 06:06 AM
elripster's Avatar
If you search, there is lots of info on doing your own alignment which can save your 50 bucks.
Frank
Old May 9, 2007 | 06:33 PM
chrishf12's Avatar
AALs went in Saturday.
And when I took it for an alignment today I found out that my passenger idler arm and steering stablizer is shot. Is $90 for a new idler arm about right??
Hopefully i can get some pics up tomorrow.
Old May 9, 2007 | 06:56 PM
91TPU's Avatar
there are rebuild kits for the idler arms, unless its bent you can just rebuild it very easily for quite cheap!
Old May 18, 2007 | 09:11 AM
chrishf12's Avatar
Heres a pic before alignment I wanna get a few more this weekend Next week im getting the top of the cab and passenger side painted because of sunspots.
Back end is a lil high hopefully it will look better after i put my spare back in.
Old May 18, 2007 | 09:16 AM
91TPU's Avatar
looks good, did you end up buying a new idler arm, or did you just rebuild your existing one?
Old May 18, 2007 | 05:13 PM
chrishf12's Avatar
im waiting on the rebuild kit from rustbucket. Hopefully it will be here in the next couple days.
Old May 19, 2007 | 09:08 AM
FredTJ's Avatar
How did you get 2.75" of lift from the BJ spacers ?
I assume that you also cranked the t-bars then.
Fred
Old May 19, 2007 | 10:38 AM
Sonofmayhem's Avatar
Looks good!
Old May 19, 2007 | 11:18 AM
chrishf12's Avatar
Fred
Yea I did have to crank them up but im gonna make a custom diff drop when I get around to it. And i cant go offroad till i cough up the money for some new shocks.
Old May 25, 2007 | 08:12 AM
chrishf12's Avatar
Grocery list!
Procomp ES3000 shocks all around
Procomp ES2000 steering stabilizer
New OEM Clutch Install Next week
New Passenger CV axle On the way install soon
Old May 31, 2007 | 11:22 AM
chrishf12's Avatar
Ok rebuilt the idler arm but stupid alignment shop had me replace it before they would align it and the truck still drives the same. Now radiator leaks. My think my toyota is bout to fall apart!
Old May 31, 2007 | 11:29 AM
1styota4X4's Avatar
go with ome shocks. Great ride also check out marlin crawler for your clutch i just put one in not long ago and i love it real smooth engagement
Old May 31, 2007 | 12:30 PM
frodin1's Avatar
I think he's going with the Procomps because of cost. OME's are up there with Bilsteins on cost. I think if someones on a budget, Procomps freebie deals are ok.
Old May 31, 2007 | 04:30 PM
FredTJ's Avatar
Procomps are "procraps"
Really, they're a pretty damn stiffly valved shock.
I understand a budget, however you do truely get what you pay for.
Something to consider with something that's so important to ride quality.
Fred
Old May 31, 2007 | 08:19 PM
chrishf12's Avatar
Ive heard the same about rancho and most ppl prefer procomps to rancho but thats just opinion.
And anyways its a 4wheel drive its not gonna ride like ur dads caddy! Im not goin for quality im goin for functionality that i can afford. but if you have some $$$ u want to donate to me for more expensive shocks im all for it!
Old May 31, 2007 | 08:57 PM
FredTJ's Avatar
Actually it depends on which Rancho's.
The 5000's are poop, however the 9000's are great, much better than the Procomps.
I've run them all so I can compare first hand.
There is a ton of difference in the ride quality between Procomps and the 9000's or the Procomp's and the OME's (top of the line shock BTW).
Being a 4wd doesn't make the vehicle so that it doesn't or can't ride well.
Why should it ?
Fred
Old Jun 1, 2007 | 02:38 AM
vwfastg60's Avatar
I have procomps on the rear of my truck and had rancho 5000 before. I have to say i think the procomps are better. The ranchos leaked in 5k miles and the procomps are going on 7k and still look new.
2.75 in lift from a bj spacer is insane!! I put mine on with my already relaxed Tbars and gained about 2 it seemed. I relaxed the bars even more and have been told by tons of people that i almost have stock straight axle flex. Im tempted to lower the back down a bit more and just bumpstop it so i stop pulling the bed sides apart. Hows the ride set up like that? i hated my bars turned up. To give you an idea of how relaxed my bars are i have 1/2inch of threads showing if that.
Truck looks really nice tho.
