biggest tires?
Old Mar 26, 2006 | 01:09 PM
elkdog's Avatar
biggest tires?
what would you guys say are the biggest mud tires i could put in a stock 93 4x4? i have 31/10.50's right now, but they are all weather tires.
Old Mar 26, 2006 | 03:13 PM
oly884's Avatar
Guest
Ok, so, before we get any further, the search function will help you out. This is probably THE most common question this board gets.
Now, your question:
It depends on whether you want to lift or not. I had a 90 4x4 not too long ago. 32x11.50's will fit with some rubbing, but 33x10.50's will fit quite well, a bit of rubbing, but you get to use the stock rims. If you lift it, 33x12.50's will fit just fine. 35's with a body lift. Keep in mind that an 11.5 inch wide tire it is suggested that you get new wheels, and 12.5 inches wide, it's a must. I wouldn't suggest going over 35's though, the stock IFS doesn't really like that.
Old Mar 26, 2006 | 04:00 PM
elkdog's Avatar
but what about the suspension and stuff. i already have alloy wheels, but i don't plan on a lift or changing axels or anything like that. i just want to put the biggest tires that will fit without any modifications.
Old Mar 26, 2006 | 04:06 PM
oly884's Avatar
Guest
Stock: 32x11.50's will fit with some rubbing, but 33x10.50's will fit quite well, a bit of rubbing, but you get to use the stock rims.
And it depends on how wide you're alloys are. I'm guessing 7" wide. Therefore the same as stock. You need to go to 8" wide wheels if you are going to run 12.5 inch wide tires and would be a very good idea to do that if you get 11.5" wide tires.
Old Mar 26, 2006 | 04:11 PM
oly884's Avatar
Guest
Here, I took the liberty of searching:
https://www.yotatech.com/forums/show...t=biggest+tire
Old Mar 26, 2006 | 04:33 PM
oly884's Avatar
Guest
Hey man, sorry for being harsh before. Sick + school work + other stuff = me being cranky.
Anyways, I run the metric equivalent to 33x10.50's. I don't have a lift, and I was able to use the stock wheels. They do rub a touch, nothing bad though.
Here's a great article to read that talks about the benifits of tall narrow tiresL http://www.expeditionswest.com/resea...tion_rev1.html
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
mreagen
Sep 8, 2015 03:46 PM
digdug40
Aug 28, 2015 02:24 PM
DirtRoad93
Aug 23, 2015 05:50 AM
