Arb compressor question
Old Sep 29, 2004 | 08:27 AM
doink's Avatar
anyone who has the arb compressor know of it to leak oil? i think mine is leaking slightly. anyone know what im talking about by chance?
Old Sep 29, 2004 | 08:57 AM
GRNTACO's Avatar
I don't think there is any oil in the compressor. Someone on here was talking about oil leaking from the solenoid. Possibly oil from the diff.
Old Sep 29, 2004 | 10:46 AM
george16's Avatar
It shouldn't be leaking oil from the compressor since it doesn't have any. If oil is coming out of the solenoid, it's a symptom that your diff breather is clogged or you have an air leak in your lines inside the diff. Majority of them though are caused by clogged diff breather. Have you done the diff breather mod yet? You might want to check your diff breather.
George
Old Sep 29, 2004 | 10:50 AM
doink's Avatar
i have indeed done the breather mod. ill check to see if its clogged regardless.
i think im gonna need to get a new compressor now, or fix something though, cause a gasket on the compressor is letting out air..perhaps that repair kit is in order?
Old Sep 29, 2004 | 03:25 PM
george16's Avatar
Try calling Tim Lund of ARB in Seattle. ARB have one of the best customer service. He's been a great help to me when I had a problem on the o-ring during my installation.
George
Old Sep 29, 2004 | 03:29 PM
GRNTACO's Avatar
Where on the compressor is the air leaking out of?
I can second that ARB has the best customer service. My compressor died (a dead short in the motor) I sent it there and had a new unit by weeks end. It's possible they can fix the air leak under warranty.
Old Sep 29, 2004 | 05:14 PM
doink's Avatar
i borrowed this picture from robinhood's post about his arbs and gears.
i circle where i think its leaking..if i remember correctly.
Old Sep 29, 2004 | 07:44 PM
Arnold's Avatar
IIRC, there's an o-ring under there. Probably just needs replacing.
Old Sep 29, 2004 | 08:07 PM
GRNTACO's Avatar
Maybe the bolt on the other end needs to be tightend. It's always something simple.
Old Sep 30, 2004 | 11:18 AM
Joe's Avatar
Joe
I'll second that comment - depending on how long you have had the compressor installed and how many "rough" trails you've been on - you'll find that you may have to re-tighten that bolt a couple times a year. After the second year it's always a good idea to take the can off and give the lip a good cleaning. Put a little lubricant on the O-ring and tighten it down - should hold for at least 6 months under hard use (off-road & driving on washboard roads) - a lot longer with mild use. I use Super Lube with Teflon for my O-ring lubricant. The oil is gear lube. The 7.5" front differential on Toyota's will build up a little pressure and force gear lube up the airline ever with an open breather. You really have to work the front locker to get this reaction but when the solenoid fails, just take it apart and wipe off all the lube, reassemble and you are good to go. Takes 10 minutes tops and doesn't happen very often.
I forgot to add this, just in case someone doesn't know. Use warm water with dish soap, paint in on the can and solenoids with the compressor powered up and where ever you see bubbles - you've got a leak. It's either going to be at the fittings, which means you either have to tighten them or take them off, re-Teflon tape the threads and tighten them back on or at the can lip which has been covered. If you have no leaks there but the compressor keeps going off & on at regular intervals - it's going to be in the line (very unlikely) or at the housing. In all my years running ARB's, I've only experienced leaks with the can and solenoid fittings.
Old Sep 30, 2004 | 12:11 PM
doink's Avatar
alright. ill try to see if i can fix the problem. thanks for the help guys.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
stock87yota
Jul 31, 2015 10:08 AM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
