Addco Sways w/ OME Lift. I Need help!
Here's my dilemma. The first problem that I am having is that there is about a 3/4" play on my rear linkage pins. I'm not sure if that is from the OME lift that I had put on at the same time. I have been looking for some bushings and having trouble finding something around 3/8" ID X 1 1/4" OD x 3/4" thick. Has anyone else had this problem.
My other problem is the spacers for the OME lift set up. How do I know when to use them or not at all? everything measures out about exact w/o out a driver. Still need to check w/ driver in vehical. Help please!
I'm not sure if I'm the only one but I'm not sure of the part you are referring to as the rear linkage pins? Do you mean sway bar connects (the vertical connections between the sway bar and body)?
As for spacers, others I'm sure will know more about OME stuff than I do.
Wes Whitmore
14
May 15, 2004 02:25 PM
