96 tacoma suspension ?
Old Dec 6, 2007 | 11:20 AM
96Blurple's Avatar
So I just recently got my hands on a pair of coilovers from a 05 tundra ! so my guestion is ....what will I need to do to install them on my tacoma ? also what shocks I should run on the rear ? I was told I just need to switch the top-plates out and install ...... but what will be the hight differance to balance out the rear? any help would be a huge help!!
Thanks 96 Blurple
Old Dec 6, 2007 | 11:30 AM
jjrgr21's Avatar
you need taco top plates, i just used my stock set. are you lifting the rear? then use what ever shocks suit the lift height, i lifted mine 2.5" and used shocks for a 3" lift. i used the stock tundra shocks for the front w/ the coils.
for the rear the best $ for $ solution is a new leaf pack, because the stock springs suck. i used OME leafs, if you do the same, no matter what make sure you get their bushing kit, and go ahead and get 2 new front spring bolts, seems like everyone's get seized and half to be cut.
nvdesertrunner
May 11, 2020 08:18 PM
DeathCougar
Apr 1, 2018 11:29 PM
juandulce4runner
Aug 21, 2015 07:30 PM
makemusic116
Aug 2, 2015 05:23 PM
Vargntucson
Jul 4, 2015 12:15 PM
