94 4runner 2wd ball joint spacers.
Old Mar 27, 2013 | 06:58 PM
ironworker416's Avatar
I have a 94 4runner 2wd. I looking into ball joint spacers just to give me the so cal prerunner look. My question is i have heard some 2wd's have 4wd control arms. How do i tell if i have the 2wd control arms or the 4wd arms to order the correct ball joint spacers?
Old Mar 27, 2013 | 07:42 PM
NickMiller's Avatar
A 1990-1995 2WD 4Runner (Not pickup) has a full 4WD front suspension... The only difference is that the diff and cv shafts aren't there.
I'm 99.99% sure the 4x4 ones will be the right choice, but someone else might know something I don't
Old Mar 27, 2013 | 08:08 PM
Thank you very much. Just trying to get a good 2-3 inch lift in the front without cranking on the torsion bars too much. Hopefully the ball joint spacers will do the the job.
Old Mar 29, 2013 | 07:34 AM
4Crawler's Avatar
Yep, the 2WD 4Runners should have the 4WD suspension components as noted above, but you can double check below:
- http://www.4crawler.com/4x4/ForSale/...shtml#2WDor4WD
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
ptb12
Jul 5, 2015 01:49 PM
