5.71 gears
Old Dec 10, 2009 | 08:00 PM
harbor_bomber350's Avatar
5.71 gears
so im planning on doing some gears now and i was wondering what the deal is with the 5.71 gears because nobody warranties them. are they really weak or what?
Old Dec 10, 2009 | 08:11 PM
4Crawler's Avatar
http://gearinstalls.com/410suck.htm
Old Dec 10, 2009 | 08:12 PM
muddpigg's Avatar
ZUK installs them and has had luck with setting them up. You will probably want to have the them cryo'd.
The deal is as the ratio goes up you the actual teeth of the gears become smaller and the amount of teeth actually incontact with each other is reduced. Theirs just not any room for error.
Check out gearinstall.com
Old Dec 10, 2009 | 08:14 PM
what about with a 350 under the hood
Old Dec 10, 2009 | 08:17 PM
tc's Avatar
tc
With a 350, what the hell size tire are you planning to run that will require 5.71?
Old Dec 10, 2009 | 08:22 PM
cutboggers's Avatar
don't do it.
If you got a small block you don't need to get that out of control with the gearing
Old Dec 10, 2009 | 08:23 PM
im running a set of 38.5 x 11 boggers but i want lower gears for crawling
Old Dec 10, 2009 | 08:25 PM
Hayes's Avatar
I have them and love them, they are a little too deep with only a 33" tire, but when I upgrade to 35" tires, it will be just right. I have had no problems with them and have about 5000 miles right now, but I had them set up by a guy who makes a living setting up Toyota 3rd members.
Old Dec 10, 2009 | 08:31 PM
Booosted Supra's Avatar
I Have them also in my 4runner, V6 auto on 36x12.5 and I love them, the 3.slow has some good power with them and I can actually maintain highway speeds with them. No complaints here on road or on the trail
Old Dec 10, 2009 | 08:37 PM
cutboggers's Avatar
It all depends on your drivin style.
If you like to hammer down from time to time, it's prob not a great choice.
Maybe with your narrow tire, just maybe.
dual t-cases i bet you'd appreciate more.
Old Dec 11, 2009 | 03:46 PM
tc's Avatar
tc
x2 - if you want to go REALLY slow, there simply is no better option... of course, then you don't need the 350 ...
Old Dec 11, 2009 | 03:51 PM
ryantowry_81's Avatar
with a 350 and 38's and 5.71's your highway RPMs will be through the roof!!! if you want to crawl do duals or a 4.7 kit, bit you will NEED 23 spline for a 350 and a toy case.
marginally weak 5.71's and a 350= broke !!!
IMO set up the gears for high range drivability then get t case reduction for your crawl you desire...
Old Dec 11, 2009 | 03:55 PM
xxxtreme22r's Avatar
X2 on the duals or 4.7 marlin, no sense in going that high of a gear only to brake them. I dare someone to break the marlin 4.7 gears.
Old Dec 13, 2009 | 06:13 AM
934rnr's Avatar
Dude your gonna want maybe max 4.56 gears with a 350. Your better off runing 4.10's with a 350 honestly.
Old Dec 13, 2009 | 09:25 AM
tc's Avatar
tc
4.10 ring gear is just as much of a problem as the pinion gear on 5.71 (although without the setup sensitivity)
If you want max gearset strength, 4.56 or 4.88 is where it's at.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
