35x14.50x15s - what size lift required?
Old Apr 22, 2005 | 03:03 PM
bryanr's Avatar
I will be looking to put a set of 35x14.50x15s on my 89 Toyota 4x4 this summer/fall and was curious what size lift I will need to fit them, and if anything other than the lift will be needed?
I assume standard Bushwacker flares wont cover them, so probably a set of Bushwacker cutout flares?
Thanks.
Old Apr 22, 2005 | 03:04 PM
waskillywabbit's Avatar
5-6" of lift and some fender trimming/pounding w/ properly backspaced rims.
jimbo74's Avatar
the biggest lift possible, fender trimming and a bodylift... that quite a tire in height, and very wide also....
Old Apr 22, 2005 | 04:15 PM
4Crawler's Avatar
At least a 4" IFS lift and a 2" body lift minimum. Had a buddy do 35x12.50 on a '90 Xcab (15x8-3.75" wheels) and he needed the above combo to fit the tires:
http://www.4crawler.com/4x4/ForSale/...l#Applications
Old Apr 22, 2005 | 07:22 PM
yote4x4's Avatar
i think 14.5 is a bit wide for a 35, but I guess if thats what your into...
Old Apr 23, 2005 | 08:48 AM
bryanr's Avatar
I've seen 2-3 trucks recently in my town running 33x14.50x15s but I think they will look better in 35s.
Old Apr 23, 2005 | 09:39 AM
deathrunner's Avatar
You could alwasy run a 33x12.50 on a 12" rim, that's how my truck came. I'm not fond of the look but it sounds like what you are describing. The tire looks much wider than a normal 12.50, plus it easily fit under a 4 inch IFS kit. I imagien you could runa 35x12.50 on a 12" rim and get similar results.
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
coffey50
Jul 28, 2015 10:55 AM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
