35s with 4in suspension and 2in coil spacers possible?
Old 03-23-2010, 01:20 PM
AxleIke's Avatar
Running 35's with no lift at all.
Work great.
Old 03-23-2010, 02:07 PM
arisegame20's Avatar
yeah i thought about the thinner tires. but even with them. my truck when i flex will hit the wheel well when it stuffs up in size due to the diamater of a 35 not problems with rub on the inside so the 12.50s work. Not sure why my truck doesnt fit if your does unless you dont get the tire stuffed in there.
Right now i have it lifted 6 inchs and i have the 35 dicks on it and its doing great. I have limiting straps on also that are 26inchs. Instead of cutting it right now i use those to stop the flex on the one side just before the other side starts to stuff. So unless im lifted up by a forklift or jack on one side i doubt i will be stuffed up in my wheel well right away untill i can get it modded under there.
Originally Posted by Diesel_Freak
Are you dead set on the DC MT's??? IMO the Super Swamper Radial SSR in 35/10.50 flavor is a pretty amazing tire AND can be fit with ZERO lift. Tire width, to some degree, along with Wheel BS is more important then tire HEIGHT. THese trucks have pretty open wheel wells and can fit 33's with NO lift as well as skinny 35's...
Cheers
Dave
Old 03-23-2010, 02:12 PM
anyone know if you can just get 6 inch lift coil springs? I dont like the spacer lift on the back as much as i would like solid spring. Just a comfert thing. I know the old chevy springs can give you a 4inch lift. can you just use a 2 inch chevy lift kit coil spring to gain the full 6 inch lift on the toyota?
Old 03-23-2010, 02:42 PM
AxleIke's Avatar
I could be wrong, but I thought the old chevy 4" deal was for leaf springs only.
choppe777
05-16-2016 08:00 AM
JHalcyonM
09-14-2015 01:10 AM
128keaton
09-03-2015 05:09 PM
Peevedkitten
11
08-31-2015 06:57 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: 35s with 4in suspension and 2in coil spacers possible?
