33's Versus 35's Experiences
Old Oct 18, 2007 | 01:30 PM
AxleIke's Avatar
no one will ever make "stronger" front IFS diffs. Why bother? Trail Mart swap and be done. I have never seen a front diff fail on these trucks anyway. Heard about it, never seen it. If you are worried about it, don't drive it like an idiot, and you'll be fine.
Old Oct 18, 2007 | 01:54 PM
hross14's Avatar
Whatever happens--i think it will be a fun build--i will wheel and when it breaks i will fix. I still drive this truck around town also and plan on taking trips in it--that is why i am apprehensive of nixing the IFS.
But--i have also decided that i will go the 35 route. On a side note--i will also be rebuilding/beefing-up the engine--so we will see how that turns out.
I will take pictures and when done pay a stripper to be in the Final Photo
Old Oct 18, 2007 | 05:29 PM
d0ubledown's Avatar
i've got 35's on an arb locked ifs diff. it gets used..hard. as long as you know how to work it and not be stupid...you'll be fine. no need to swap for a solid axle unless you want to burn some money and brag to your friends about how much bigger your enispay has grown...
Old Oct 19, 2007 | 07:32 AM
BajaRunner's Avatar
I'm not really a 'hard' wheeler. I do camping trips into Baja where a 4x4 is needed for an array of obstacles. I get into some hairy situations, and have never had any problems with my 35's. However, I have been stuck many times with 31's in the same areas.
On the note of worrying about the front IFS, well, I think it really depends on how you drive. I watch these amateur 4x4 videos and the guy is just pushing his truck to the absolute max. People look like they don't have a clue on how to drive their crap sometimes! I have been wheeling my truck since I was 16, and even then, I never drove it as hard as I see 40-50 year old idiots trying to pull of crap a 10 year old wouldn't even do.
Old Oct 19, 2007 | 07:54 AM
  #25
deathrunner's Avatar
I've never had 35's but they seem bigger.
Old Oct 19, 2007 | 11:34 AM
  #26
hross14's Avatar
Ya Think?
By the way--This is a slight change of direction--but what about FROR Chunks--I.e. chromoly shafts and Disc brakes--anybodt heard of somebody being able to retain the ABS after the conversion?
Old Oct 23, 2007 | 11:23 AM
  #27
melkor's Avatar
They certainly do...yep...
so what is the general consensus then? are 35's worth gearing down and the extra cost?
Old Oct 23, 2007 | 03:21 PM
  #28
FredTJ's Avatar
Well, yes IF you wheel where you really need them and have done all the other things to the vehicle that you'll need to do in order to wheel in those areas.
Fred
Old Oct 23, 2007 | 06:35 PM
  #29
d0ubledown's Avatar
yes. only if you do everthing needed for them to work...properly.
Old Oct 25, 2007 | 10:28 AM
  #30
hross14's Avatar
I will be properly set up----Just got my New-To-Me 99 4Runner --time to start cutting and getting rid of the soccer mom CRAP.
Old Nov 3, 2007 | 07:22 AM
  #31
ninjarunner's Avatar
I have a 99 4 runner with a 6in lift and 35's, it is supercharged and locked, I have retained the IFS cause I drive it on 250 mile rips once a week for work. I love it, I get to drive over things and through things with ease that I could never do with the same rig with only 33's and a 2 in lift.
Old Nov 4, 2007 | 05:23 PM
  #32
bigarms23's Avatar
I dont know the difference but i do know that when both tires are aired down the 33 measures 31 and 35s measure 33
Old Nov 26, 2007 | 09:46 AM
  #33
hross14's Avatar
So final set up i am in the processes of installing--Just an FYI if curious and open for opinions--Should be done by Febuary
--Weasy-ied the heads and cams--
--Doug Thorely Headers--
--High Flow cats and rest of exhaust--
--Detriot Locker in Rear (5.29's)--
--Detriot True Track LSD up front (5.29's)--
--1.5" Roger Brown BL--
--SS#7 and shaved A-Arms--
--Left From Inchworm (5.71 Low gear and twin sticked)--
--Mick Classic II's and 35's (Nitto (Muds) or Yokohama (Muds)
--ORS Alloy Axle Chunks.
That is now the final set up--not including bumper, winch, etc....
Final note--i am not a crazy wheeler so with any luck--i wont go through the IFS stuff to often--hoping the CV's will be the weak link--since i have an extra set already So what do youds think?
Old Nov 26, 2007 | 10:10 AM
  #34
jagger_snitt's Avatar
35's allow you to roll over most obstacles just because of the size of them.
Their size makes them easier to conquer obstacles as long as you are properly geared,33's will be fine you will just have to work a little harder.
A lot can be done with smaller tires at the sacrifice of body damage.
The larger tires allow you to clear your diffs and longer wheel based rear ends.
Old Nov 26, 2007 | 10:18 AM
  #35
TRD_JW's Avatar
my delima
im goint throught the same thing keep the 33 10.50 or go up to the 35 12.50 im running open front and rear diff but that is goint to change soon the front is getting welded sometime this week for a little extra traction and gearing is no problem since i did the chevy 262 swap
so what do you guys this will it be worth it to me to to runt a 35 with this set up.
Old Nov 26, 2007 | 10:33 AM
  #36
4runnin2002's Avatar
not planning on turning?
Old Nov 26, 2007 | 10:49 AM
  #37
tc's Avatar
tc
Not unless he has a twinstick ... and even then it will be interesting.
Since you won't be able to turn, you can fit a much larger tire!
Old Nov 26, 2007 | 11:24 AM
  #38
hross14's Avatar
Wouldnt weld the front---ohhh no That is why i stayed with an LSD up front--Hopefully the wheel will slip before i pop the front-- --but like the others say--dont you like turning?
Old Nov 26, 2007 | 11:27 AM
  #39
TRD_JW's Avatar
well i have maunal hubs so on the road i wouldnt matter and i dont think that in the dirt you would have to much of a turning problem
Old Nov 26, 2007 | 11:35 AM
  #40
AxleIke's Avatar
Twin stick does nothing on a welded diff. He'd have to unlock a hub.
As for turning, it depends on where you live. Out west, we have high traction stuff, and turning with a spooled or welded front is near impossible. East, in the mud, it seems to be pretty easy.
As for 35's, again, depends on where you are. And what type of truck you have. 35's will obviously be bigger, and thus put more strain on your front end. If you feel like that's fine, or are prepared to deal with any breakage out on the trail, then go for it.
