Old Mar 30, 2016, 03:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Tire Repair and Maintenance
Print Wikipost
3" lift, what size tires
Old Sep 14, 2005 | 01:10 PM
Nick Cuban's Avatar
i just put on my 3" toytec lift and i am in the hunt for tires. im getting the firestone destination m/ts, i want to keep my stock rims but i dont want it to rub of hit my control arms or whatever it is that the top of the front shock bolts to. any suggestions with pics of trucks with stock rims will be good. thanks
Old Sep 14, 2005 | 01:12 PM
EWAYota's Avatar
maybe a 32x10.50 or 32x11.50?
Old Sep 14, 2005 | 01:25 PM
Nick Cuban's Avatar
im planning on 285/70 or 75 (whichever size my stock ones are)r/16, but there isnt much room between the tire and the truck (on the inside) so i was curious.
Old Sep 14, 2005 | 01:50 PM
94x4's Avatar
Guest
I'd say the 32x11.50x15's, but since you've the extra room, why not 33x11.50x15's?
Old Sep 14, 2005 | 01:53 PM
Nick Cuban's Avatar
there is like an inch between my stock tires and the control arm.
Old Sep 14, 2005 | 02:09 PM
ErikJeanna's Avatar
33x16's won't work without rubbing in and out of driveways and ANY slight off camber situations. Sucks. I have a thread about my FS Destination's here:
https://www.yotatech.com/forums/f2/oh-yeah-new-tires-just-came-64558/
Old Sep 14, 2005 | 06:47 PM
Nick Cuban's Avatar
i hate that tehy rubbed on your rig, i really want them anyone with a tacoma with them with a 3" lift have the same problem?
Old Sep 14, 2005 | 08:24 PM
94x4's Avatar
Guest
Apply "wheel spacers", no wheel rub.
Old Sep 14, 2005 | 09:12 PM
LarsDennert's Avatar
Instead he'll have rub in the fenders from the increased outward position. It'll be bad enough as it is.
Fitting 33's is not a function of lift unless you either limit wheel uptravel or create clearance in other ways. Control arm rubbing is best solved by either clearancing the arms or replacing them.
Old Sep 15, 2005 | 09:27 AM
ASU4runner's Avatar
33x11.50x15's wont work anyway.. i think he has a 16" rim which carry with it a larger caliper that wont allow for a smaller rim size ( at least thats how 4runners are ).
Old Sep 15, 2005 | 11:37 AM
Nick Cuban's Avatar
im gonna have to get wheel spacers, or find some 16" rims that have the right backspacing. i guess
Old Sep 15, 2005 | 05:45 PM
ErikJeanna's Avatar
My 16" rims have 4.5" of backspacing. Just an FYI
Old Sep 16, 2005 | 05:55 PM
i_love_tacos's Avatar
i have a 3 inch lift with 32x11.5R15 tires and the only rub i get is from the fenders. but thats only because theres pieces of plastic stickin out. other than that it doesnt rub anywhere else. i run 15x10 Micky Thompson Classic ll wheels.
Old Sep 16, 2005 | 06:35 PM
bflooks's Avatar
ASU4runner....are you running the 33's on the lift you have? no body lift involved? if so...which tire exactly? i am taking the step up when the stuff arrives.
Old Sep 17, 2005 | 10:03 AM
MONKEYBOY's Avatar
Have you considered 255/85 r16s (33") or 235/85's (32")? They fit stock rims, aren't too wide, and are cheaper than 285's. I'm looking at adding new tires to an '03 Taco with the same amount of lift and those seem to be the easiest fit on stock rims.
Old Feb 12, 2008 | 12:45 PM
tacoma728's Avatar
I would just do a 3" bodylift and leave the 33s. You can actually fit 35s with six inches of lift.
Old Feb 12, 2008 | 01:52 PM
AxleIke's Avatar
Holy old thread batman.
Old Feb 12, 2008 | 02:05 PM
tacoma728's Avatar
yes, yes it is. A good one however, I think there is some good things pointed out here.
82yodahickman
34
May 16, 2017 01:00 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
Yotoder865
Jul 9, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
