2nd gen rear leaf spring conversion?
Old Jan 12, 2008 | 03:47 PM
4rnnr33's Avatar
ya i got 5in trail gear springs so you would think that it shouldnt be to far off
Old Jan 12, 2008 | 05:11 PM
Elvota's Avatar
Well... keep in mind that even an 1" one way or the other can really change things. Give you a bad shackle angle or cause the wheels to bite into your wheel wells.
You need to figure out what the eye to eye measurement is on the TG springs as well as the All Pro. Also need to figure out the length from the front eye to axle pad bolt.
If the TG springs are not exactley the same as the All Pro springs then you'll need to adjust your mounts accordingly.
Old Jan 13, 2008 | 08:12 PM
4rnnr33's Avatar
ya thats a good point elvota i think ill use your measurements and get everything tacked on and see how far off it is then adjust accordingly. hey rockrunner what springs are you using??
Old Jan 13, 2008 | 08:14 PM
91RockRunner's Avatar
I also have all pro 6in springs as well. duuudeee... i totally forgot to take pics/measurements for you today while I was out there. My bad. Ill get on it.
Old Jan 14, 2008 | 01:27 PM
  #25
Rear leaf spring mounts
<br><br>
Drivers side, front mount. <br>
[IMG][/IMG]<br>
<br>
rear mount. I also asked Elvota if he could sent me his pics/measurements, which I went off of, but he suggested that he would go to 5.5inches for the rear mount because of his shackle angle. From the end of the from to center hole of the mount (if attachted to frame) is 5 1/2 inches.
<br>
<br> I used the SKY manufacturing rear shock mount because SKY man. is a semi local fab shop around here, plus I picked up two diff armors as well. The shock mount was $60, and each diff armor was $35
<br>
[IMG][/IMG]
<br>centering your axle and spring perches after you figure out your driveshaft angle is straight forward - making sure the same measurments on both sides
Old Jan 14, 2008 | 01:29 PM
  #26
dammit.. that first picture is suppose to say "3 1/4 in" NOT 3 in... but its a 1/4in, so not a biggie. Just an fyi.
Old Jan 14, 2008 | 01:34 PM
  #27
Elvota's Avatar
91RockRunner... you may want to put some weight on your axle before you get to far. This will allow you to verify your shackle angle and make sure you like the way everything is going to sit.
Of course over time the springs will settle or flatten out, which will relax the shackle angle a bit more.
Now is also the time to see where you axle lines up in relation to the wheel well opening.
Maybe you have done all this already. If so, just ignore me.
Old Jan 14, 2008 | 01:42 PM
  #28
*ignored*
Old Jan 14, 2008 | 01:50 PM
  #29
Elvota's Avatar
Originally Posted by 91RockRunner
*ignored*
Dang it... why am I getting so used to that response?
Old Jan 20, 2008 | 05:21 PM
  #30
4rnnr33's Avatar
hey rockrunner do you think that you could post some pictures of how you mounted your shocks to the stock x member??
Old Jan 29, 2008 | 01:26 PM
  #31
4rnr's Avatar
check out my build thread in my sig.
I beleive I was one of the first to do this, marlin had not even done one yet.
Old Jan 29, 2008 | 02:02 PM
  #32
One of the first to do a rear leaf conversion?
hmmmm
Old Jan 30, 2008 | 07:03 AM
  #33
4rnr's Avatar
hmmmm
Did I stutter?
Old Jan 30, 2008 | 07:09 AM
  #34
4Crawler's Avatar
This one of the first rear coil->leaf swaps I know of, back in '99:
- http://toyota.off-road.com/toyota/ar....jsp?id=300933
Old Jan 30, 2008 | 07:26 AM
  #35
4rnr's Avatar
didnt say I was the first, but when I did mine I couldnt find any write up's or anyone on the boards who give me any info or anyone who had done this. That is including Marlin. Which is why they sent a ton of different parts to experiment with on my truck to find what worked the best.
Im sure someone did a rear leaf swap in 1990. But I couldnt find poop about it.
BTW I cant read anything on you link past the name "Chris Geiger"
Now lets see if we can find more than one! I will link to them in my build.
Old Jan 30, 2008 | 07:36 AM
  #36
4Crawler's Avatar
Here is the article, written by Chris when he was still a "regular guy", and I know the article has been available since written in 1999, so should have turned up in a search.
Rock Runner rear leaf springs
May 1, 1999
By:Chris Geiger
Toyota at Off-Road.com
For most of it's life the coil spring suspension on the back of my 4Runner has done a good job both on the trail and off. However after swapping in a solid front axle from All Pro Off Road and installing 35" tires, I needed a bit more lift in the rear to match the front solid axle conversion and provide clearance for the 35" tires. There were a number of problems with lifting the coil suspension beyond the 3" it already had. See section bellow on "Why Change to Leafs" for more details.
The hardest part of converting my rear coil suspension to leaf springs was removing the coil suspension and all of it's brackets from the axle and frame. This took by far the most time of all the steps involved. There are five different control arms and each of them has two brackets, one at each end. The pan hard crossmember was also removed. My original plan was to keep the upper control arms In case I needed them to control axle wrap. I also planned to keep the rear sway bar to control lean on the highway. As it turns out neither was possible and to do things correctly both must be removed. The rear exhaust also needed to be cut and will be relocated later.
The soft feel and poor road performance of a lifted coil suspension was annoying on the highway. The truck had a tendency to go all over the road and was a hand full to control. Off-road the truck had a tendency to feel tipsy and would lean easily, especially on side hills. This caused me to choose a very conservative route when choosing the components for the rear suspension. To control sway and limit that tipsy feeling that a soft suspension can give I choose to get a relatively stiff leaf spring: an All Pro 8 leaf pack with an extra torque leaf to control axle wrap. By making the spring pack as long as possible I am able to control axle wrap and still allow good rear travel without using a torque rod. The springs I choose are 56" long that have 5.5" of lift when compared to a 1989 Toyota leaf spring. These springs can also be installed on any 1979-1995 truck or leaf sprung 4Runner. Some welding and cutting is required.
The springs are mounted using four spring hangers, just like the factory uses. These are relatively cheep to purchase and are easy to weld onto the frame. The ones used here are from a 1985 truck and can be ordered directly from Toyota you can still see the Toyota part number label in this picture. You can also see the two tiny tack welds that hold the hangars in place temporally. It was hard to determine where exactly to put the springs so every thing was tack welded in place to allow for easy changes. To reduce rubbing problems I had with my 35" tires in the rear I choose to move the rear axle back 1.5". This also reduces the amount of overhang behind the rear axle. With the front axle moved forward 1" the overall wheelbase is now 105.5".
On the axle a 2" longer than normal spring perch was made. The spring perches Toyota uses are 4" long. By making the perches a little longer (6" total) the axle does not wrap as easily do to the larger spring contact area. Shorter perches allow more travel but also allow more wrap up of the springs. Making a spring perch is easy. Just take a 2" X 3" piece of tubing and cut a 3" hole into it using a drill press. You can also create a little lift by using 2" X 4" steel. Spring perches can also be purchased from a number of custom shops. You can see here the axle with the original link brackets removed. The sway bar mounts were retained for possible future use.
I made a set of shackles for the rear using flat bar steel. There is no cross-bar on these shackles to allow the leaf spring to twist a little, thus allowing a little more travel. The corners of the shackles were rounded to prevent binding with the frame. Greaseable shackle bolts and bushings were used and allow for easy lubing. Adding a shot of grease at every oil change should keep the squeaks under control.
With the mounts all tacked into place the tires were installed and the truck put down on the ground to see if everything is in the proper place, then the entire thing was dissembled and the finish welding was completed. Next the suspension was assembled again and the welds were painted.
The pan hard rod crossmember was removed to allow the Rancho 9012 shocks to be mounted as high as possible. These were mounted upside down to prevent damage to the adjusters. A new crossmember was created using 2" round tubing and 2 pieces of flat bar. The 1" body lift I have allowed for a little extra space for the new crossmember to be mounted slightly above the frame. A U bolt flip kit was used to make the under side of the axle as clean as possible. There is nothing under the axle to hang up on now. Bump stops were installed to limit compression, preventing damage to the springs.
My proportioning valve was connected to the pan hard rod crossmember and when this was removed the valve mount was removed too. So a small bracket was fabed up that allows the valve to be mounted in the same location as before. The valve arm has been tied up to increase rear breaking effectiveness.
Why Change to Leafs?
There are a host of other problems associated with modifying the original coil system to accommodate the 5"+ of rear lift I needed to match the front solid axle conversion and clear my 35". When lifting the rear suspension it is necessary to relocate the mounting points so as to level the control arms. If the control arms are not nearly level with the ground the rear axle induces bump steer when the body rolls to one side or you hit a bump with one of the rear tires.
The axle really needed to be moved back by 1.5" to center it in the wheel well. This I felt was the best way to clear the 35"s tires with the minimum lift possible. Do to the close proximity of the coil springs, shocks, and panhard tower it would not be easy to move the original system back. With the leaf springs, choosing axle position is just a matter of welding the perches in the proper location.
The brackets I used for the rear coil suspension were the Pro Comp 4" rear lift along with custom coil springs made by A1 spring. The Pro comp kit comes with 5 drop brackets, one for each of the rear control arms. The "upper" two drop brackets bolt onto the existing upper axle brackets on the differential. This causes more leverage to be placed on the original bracket and several people have reported that left upper bracket has been ripped off of the differential.
The lower bracket extensions do not seem to have any failure problems however they hang down quite low and are constantly hitting and hanging up on the trail.
The Panhard rod relocation bracket drops the panhard rod by about 2" but with the rear lift at about 5.5" the pan hard rod is still at a an angle. The main problem with this is that it causes the rear axle to shift to the right as the rear suspension drops. This causes the drive shaft to hit the gas tank and reduces spring extension because the suspension binds as it is pulled to the right by the panhard rod. The pan hard rod really needs to be level when the truck is sitting on level ground.
I truly believe that all of these problems could be solved except for the ground clearance issues related to the lower control arms. To solve these problems and set up the rear end so that it would be safe to drive and get the full 20" of travel it is capable of would require most of the suspension to be cut off and replaced or relocated. This would be a very time consuming process and would require lots of trial and error work.
Overall Results
The coil spring suspensions I have used over the years include stock, 1.5" Downey coils, 3" coil and spacer kit, 4" Pro Comp and now the leaf spring swap. Leaf springs have netted about 6" of rear lift and the truck sits level now. The rear travel as measured on a 20 degree ramp right after installation is 19.5" of articulation. Two weeks later I performed the same teat and as predicted by Jon at All Pro the springs would travel further after breaking in. Now I measure 21" of rear articulation.
With the downey 3" lift I got about 19", with the Pro Comp 4" lift I got 20.5" While the downey 3" lift worked and drove very well the Pro Comp kit springs were way too soft and they caused the truck to be much less stable on and off road.
The springs work wonderfully and provide a very nice controlled ride. They are able to support much more weigh than any of the coil suspensions and provide a very comfy ride. When people take a ride in my truck they can't believe it's sitting on leaf springs. I do not plan to put sway bars on like I had used with the coil suspension. The leaf spring suspension does not allow body roll like the coil suspension did. Over all the rear suspension made a huge improvement both in terms of off road ride but also in load handling and street ride. I can confidently recommend these springs for any Toyota truck or 4Runner.
Contact Info:
Springs and Installation by: All Pro Off Road
25171 North Palm B3
Hemet, CA 92543
909-658-7077
Shocks: Rancho Suspension
P.O. Box 5429
Long Beach, CA 90805
213-630-0700
Old Jan 30, 2008 | 07:52 AM
  #37
4rnr's Avatar
Never been to "toyotaoffroad.com"
So so far im the second guy to do this
Old Jan 30, 2008 | 08:01 AM
  #38
4Crawler's Avatar
The off-road.com site predates most every other off-road site out there:
- http://www.off-road.com/offroad/stat....jsp?id=373124
Great source of older content and technical articles, although that stuff is a little hard to find as there has been some updates and not all the old articles have been changed to reflect those updates.
Old Jan 30, 2008 | 08:41 PM
  #39
Pretty brave saying you think you were though. Im sure that there are many other ppl out there who has done one, yet knows nothing about forums... i didnt know about forums until i started searching online and stumbled across this particular one...
But im not trying to start really. And plus... I would if I knew about your post, i would have used your thread to help with my rear leaf.. funny thing is.. i had bought an '89 while in iraq; came back, decided I want a 4door only AFTER I had purchaced the front and rear lift for the '89.. so I had a prefectly good rear leaf lift.. so why waste it? That is when I stumbled across yotatech. I didnt want to spend the money on a 3 link system since I couldnt return the rear leaf.
anyways... yea.. thats my story about the rear leaf conv. .
Old Jan 31, 2008 | 06:54 AM
  #40
4rnr's Avatar
No bravery needed, while I know I wasnt the first and never said I was. I said "I beleive I was one of the first." Besides, while I can think of 3 4runners that inspired me to do the leaf swap far before I did it. They did not do any kind of writeup and hense for the purposes of a forum they are NO help. I wouldnt be surprised if you could find a write up older than mine (more than one in an ancient forum, which I do know of just never went there) Maybe you could find 2 If you can find 5 ill edit my post
Jesus who cares.
Im still second guy
