2" body lift
Old Aug 25, 2006 | 12:43 PM
mattdon's Avatar
Question 2" body lift
Im starting to get into the offroad upgrades and I was thinking of doing a 2" body lift on my truck because its way cheaper than doing a suspension lift. Is this a good choice to go with or will it decrease my offroad ability, tip easier, ride differently etc.
thanks
Old Aug 26, 2006 | 07:22 AM
tc's Avatar
tc
Seems like everyone has a different opinion - search around and you'll see all the pluses and minuses. Also check out www.4crawler.com.
The big knock on body lifts is that they don't increase your ground clearance other than the larger tires. In your searches, check out "drivetrain lifts" that go with a body lift. It will help minimize some of the bodylift issues and provides practical ground clearance improvement.
Old Aug 26, 2006 | 07:34 AM
spindleshanks's Avatar
Typically body lifts are done in conjunction with a suspension lift. I installed and ran my body lift for six months before installing the suspension upgrades. I noticed slightly more tendency of the truck to lean into corners, but let's face it, the stock Bilsteins were so soft that the truck behaved that way right off the factory floor.
Read 4Crawlers site, as recommended above. I used his extensive and very accurate instructions to install my body lift. Somewhere on this forum I started a thread detailing the few issues involved in the install that RB didn't cover at 4Crawler but I can't find it.
When I finally installed my suspension lift a couple of weeks ago, it fixed any handling issues I ever had, whether or not they were related to the body lift.
I think the body lift itself cannot diminish your offroading ability...if you do it properly. This means you may have to extend your steering, shifter (if manual) shift linkage (if automatic), bumpers, lower your radiator, "customize" your shifter portal on the floor, etc.
Old Aug 26, 2006 | 07:35 AM
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
upongame619
Aug 1, 2015 12:12 AM
Cabell
Jul 24, 2015 12:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
