1.25" budget boost possible?
Old Sep 26, 2007 | 07:02 PM
n16ht5's Avatar
OK i have a 94 runner that sags about 3/4" in the rear and looks like a dog dragging its legs . it pretty much only sees snow so I dont need to spend more than is necessary to get a 2.5" lift with BJ spacers and panhard spacer and w/e. Could I get away with a 2" coil spacer in the rear and crank the torsion bars an 1" or 1.5"? figuring it sags, the 2" would add to about 1.25-1.5" lift I am guessing? then crank a bit.. would it lose all flex and ride like a rock in the front? Has anyone made their own coil spacers? Do you need bump stop spacers when you run spacers in the back? Do the OME 2" lift coils ride at a full 2"? I'm new to IFS, just sold my 85 .
thanks a lot
Chris
Old Sep 27, 2007 | 08:51 AM
tc's Avatar
tc
Actually, 2" would probably level it out nicely - maybe a slight rake.
You can adjust the tbars to level it out if necessary - the small amount you will need (I'm thinking 0.5" or so) shouldn't affect the ride dramatically.
No you won't need any spacers, brake line extensions, etc - you're simply putting it back to stock height. You will need an alignment after doing these adjustments though.
Old Sep 27, 2007 | 05:12 PM
44Runner's Avatar
saggy rear is no fun. Get a spacer, then crank the tbars if needed. There is no problem with that.
TheBFA
Feb 15, 2020 06:55 AM
buckz6319
Aug 5, 2017 03:50 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
dirk89
Oct 1, 2015 05:15 PM
charlie_fong
Sep 27, 2015 10:06 PM
