99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
tundra TPS sensor
Old Jan 26, 2004 | 08:48 PM
alexg1323's Avatar
tundra TPS sensor
can somone tell me the specified resistance values for the throttle position sensor on the 2000 tundra. I dont have the book and this is all i need to know. thanks.
Old Jan 27, 2004 | 01:52 PM
Mohamed's Avatar
Re: tundra TPS sensor
I'll look it up tonight and get back to ya.
Old Jan 27, 2004 | 07:05 PM
alexg1323's Avatar
thanks
Old Jan 27, 2004 | 08:19 PM
Mohamed's Avatar
Originally posted by alexg1323
thanks
Oh thanks for replying, I almost forgot.
Anyway, the manual accord to SF-31, states that for the 2UZ-FE engine (V8), the resistance is 1.25-2.35 kOhms at 20C (or 68 F) in between terminal VC & E2. If you need me to fax over where the measurement needs to be taken off the terminal, pm me with a valid fax number.
Oh almost forgot, if you need the 5VZ-FE (V6), it indicates to add vaccum to throttle opener and measure resistance on terminal for
1) Fully closed - between VTA & E2 - 0.2-5.7 Kohms
2) Fully open - between VTA & E2 - 2.0-10.2 Kohms
3) unknown - between VC & E2 - 2.5-5.9 kohms
Old Jan 27, 2004 | 09:28 PM
alexg1323's Avatar
Yea i need the resistance range for the throttle position sensor on the V8 i know it must be off i keep getting a CEL for intermediate and high voltage from the TPS. If you can give me the opened, closed, and installed ohm ranges for the V8 id be much indebt thanks a bunch
Old Jan 28, 2004 | 06:32 AM
Mohamed's Avatar
From what I remember in the manual, no ranges where given as far as position, just the range that you see there of 1.25 - 2.35 kOhms resistance.
I look again tonight, but I think that's all that was in the manual.
Old Jan 29, 2004 | 07:08 AM
Mohamed's Avatar
Ya I checked it out, that's all it says in the manual, that range.
Old Mar 6, 2020 | 10:35 AM
Davidk502's Avatar
Need the ohm rating for the 4.7 V8 tps 2000
What is the ohm setting and idle voltage for the 4.7 l V8
2000 Toyota Tundra? Please and thank you. Can't seem to find information on this anywhere
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
