99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Old Mar 31, 2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tundra Interior Guides
Print Wikipost
Programming a '05 Tundra remote
Old Mar 20, 2006 | 06:37 PM
cjpil21's Avatar
Unhappy Programming a '05 Tundra remote??
I've been searching like crazy to find instructions on how to program a key FOB for a '05 Tundra. We bought it as a demo and it came with no remotes. I bought the whole keyless entry system from e-bay just to use the remotes. Now all I need are the instructions. Please HELP!!!!
Old Mar 21, 2006 | 06:18 AM
nhparrot's Avatar
Is it a Double Cab or an Access Cab. They have different keyless entry systems. Is it factory (some distributor areas install aftermarket and not the factory option) - what is the FCC #?
Old Mar 22, 2006 | 07:08 PM
cjpil21's Avatar
It is a double cab. Factory system for all I know. The truck is out of town right now so I can't be any more specific. Thanks for your reply.
Old Mar 23, 2006 | 10:50 AM
nhparrot's Avatar
To add an additional remote on the DC factory system
1. Insert key into ignition key cylinder, then pull it out. (Assume from step 3 that driver door is open)
Perform steps 2 & 3 Within 40 sec.
2. Press door lock control switch (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval.
3. Close and open driver side door
Perform steps 4 , 5, 6 & 7 Within 40 sec.
4. Press door lock control switch again (for manual operation) 5 times to LOCK/UNLOCK at approx. 1 sec. interval.
5. Insert key into ignition key cylinder.
6. Turn ignition switch from LOCK to ON and back to LOCK at approximately
1 second intervals, 1 time (This sets ADD Mode)
7. Remove key from ignition key cylinder.
Within 3 sec, Body ECU automatically performs power door LOCK-UNLOCK operation to inform which mode has been selected. (1 LOCK-UNLOCK)
Perform steps 8 & 9 Within 40 sec.
8. Press LOCK and UNLOCK switches on transmitter simultaneously within 1.5 sec.
within 3 secs of step 8 perform step 9
9. Press either switch for more than 1.5 sec.
Within 3 sec,Body ECU automatically performs power door LOCK-UNLOCK operation to show whether registration has been completed correctly or not.
LOCK-UNLOCK Occurs Once - Registration of recognition code has been completed.
LOCK-UNLOCK Occurs Twice - Registration of recognition code has failed.
zytra
Jan 24, 2019 03:16 PM
ToyotaMD
Nov 9, 2015 11:53 AM
LCE_Performance
Oct 1, 2015 01:03 PM
beltcutter
Sep 30, 2015 06:14 AM
4runnerFireman
Sep 29, 2015 06:24 AM
